08-23-2023, 12:02 PM | #1 |
Rep 6
Just washed car and now automatic pdc is not working
Here's the story, I just washed my car last night and even drove it albeit a short distance to another parking spot. This morning I drive off to go to work and the error messages come up, Automatic PDC malfunction so basically now I only have cameras to work with no sensor beeps and object marking and no automatic parking, etc. Something to note, I do have an aftermarket csl grill, had it for almost a month and have not had issues with the sensors after installed even after days of very heavy rain, so I can't imagine a car wash would have damaged the sensors especially since this was not my first wash of the car with a pressure washer after grill replacement. So any ideas on what it could be?
08-23-2023, 12:21 PM | #2 |
6723
Rep 6,749
Your pressure washer damaged a sensor in your aftermarket grille. Just because it didn’t have an issue before doesn’t mean it couldn’t happen.
forcefed2571.00 M4ROLLIN20182.00 |
08-23-2023, 12:32 PM | #3 |
3007
Rep 2,670
Drives: 2024 M4 Convertible
Check the sensors on the grill. You may have not set them properly enough in the grill so that now that you've knocked it slightly with the washer, it's just out of place enough to cause problems now.
M4ROLLIN20182.00 |
08-23-2023, 02:11 PM | #4 |
2571
Rep 1,935
Try rebooting idrive by holding the power button for like 10-15 seconds, if that doesn't work then go to the dealer and play dumb.
08-23-2023, 11:55 PM | #5 |
Rep 269
Drives: 2024 BMW M4 COMPETITION
First thing I did with my new comp…plugged in my Autel scanner and saw the PDC errors and basically reset the system. Worked like a charm, however, in my case there was no known physical damage. I also got a “rear differential lock” malfunction a couple weeks ago, car went in some sort of limp/restricted mode after I went over some train tracks; steering/handling, power etc. were greatly affected. Got to my shop, hooked it up, reset the system and back to normal it goes. It’s worthy to note a couple of other systems I hadn’t noticed that were not working properly resumed to normal operations after the clear.(ie when you’re parking and the front camera switches to show you a Birds Eye view of the car/object in front of you wasn’t working etc)
Anyway, I’d do this this first then if that doesn’t work you know it’s a physical issue that might have been caused by damage, loose connections, etc. Good luck man |
08-24-2023, 08:13 AM | #6 | |
Rep 54
08-24-2023, 09:11 AM | #7 |
Rep 269
[/QUOTE]
Can you link the Autel scanner you are using to reset the PDC system? https://www.amazon.com/Autel-Diagnos...85262537&psc=1 |
429throttle60.00 |
08-24-2023, 06:26 PM | #8 |
Rep 6
Ok, i did try using a regular obd scanner but it doesnt pick up the errors which is weird any thoughts on that? Or a regular bluetooth obd scanner just doesnt have the capabilities to detect something like that?
08-24-2023, 07:01 PM | #9 | |
Rep 269
If you were in southern Cali I would’ve definitely helped out a fellow member but Im confident you’ll be fine with the scenario I gave you. |
08-24-2023, 07:47 PM | #10 |
Rep 218
Drives: 2023 M3 Comp Xdrive
I wondered if other people had this issue. Every time I do a thorough detailing with my power washer I’ll have it pop up for a few days after. I haven’t washed in a month and haven’t noticed any PDC warnings. I even had the diff lock warning once but never came back.
Tags |
g80, pdc problem |
