05-16-2023, 08:21 AM | #1 |
Rep 1,125
Drives: 2015 BMW 435i Xdrive MSport
Ohlins, KWs, Bilstein - Which is Better?
Hi everyone,
Since completing my OE M Sport conversion I've begun research on my suspension. I'm Xdrive with a rear LSD, so I'm looking for something that will perform great but still have some comfort. I have my wheels and tires picked out but I'm looking to lower first and then put on some wheels (I don't want wack fitment lol). The route I'm taking this car is GT inspired. Please let me know your thoughts and experiences with the suspension listed in the title! Keep in mind, I plan to also replace all control arms with the solid bushing arms offered by VAC or Turner Motorsports. Thank you.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
05-16-2023, 10:05 AM | #3 |
Rep 1,125
$2500-$3500. Sweet spot would be right around $2800.
05-16-2023, 11:17 AM | #4 |
5942
Rep 10,314
Thanks for the details. This is a reasonable budget. Suggest to plan for a 4 wheel alignment after installation.
Any concerns about comfort while driving on less-than-perfect East Coast roads? Bilstein coilovers would not be my first choice - they tend to be too harsh. Any lowering target in mind? |
05-16-2023, 11:31 AM | #5 | |
Rep 1,125
05-16-2023, 12:26 PM | #6 |
Rep 136
Hey - im xdrive and on kw street comforts, obviously deal with the same roads you have, and have had a set of wheels that were 18x9+32 squared and only had to trim some of the front bumper bracket to eliminate rubbing (tire was believe a 255/40). dont see a need for camber plates.
just had monoball bushings done up front also. great all around package. I'll have to get my new height measurements but believe im lowered around 1.5" give or take. pics are from that wheel setup and height of car, wouldnt suggest going much lower on xdrive. |
Boostedphil698452.50 |
05-16-2023, 12:29 PM | #7 |
Rep 787
I don't recommend combining monoballs with bilstein shocks and or camber plates. All together this will be a harsh ride as each of them increase noise, vibration or harshness. . Potentially intolerable for a daily driver depending on the roads where you live. At your quoted budget I'd consider looking into custom dampers (as I did) or just doing the coilovers first. Then deciding if you really need camber plates or control arms on top of that. It's tempting to do it all at once and save on labor overlap but you won't be able to tell which bits push the car past the point of acceptability and will potentially spend more time/money removing parts to answer the question at that point. Aside from wheel gap( easily remedied with mild lowering springs) , tell us what you aim to improve and we can try to make more targeted recommendations.
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
05-16-2023, 12:41 PM | #8 | |
Rep 1,125
05-16-2023, 01:23 PM | #9 |
3128
Rep 4,378
in your situation, this is what i'd do...
eibach pro-kit 5-22 springs wrapped over koni sport yellow dampers and F80 bumpstops. however, if you're set on coils, my 1st choice would be Ohlins, KW SC(2nd) i have VAC thrust arms and highly recommend at least it(UCA), or both. for wheels, consider staggered, especially if you're making big power... 18x9 ET30 front, 18x10 ET40 rear with 245/40/18(25.7")+275/35/18(25.6") or 255/40/18(26.0")+285/35/18(25.9"). either combination is suitable for x-drive. rotate across axle with non-directional tires. |
05-16-2023, 01:56 PM | #10 | |
Rep 1,125
alohasurftoad3127.50 |
05-16-2023, 02:42 PM | #11 |
24463
Rep 191,414
The choice ultimately depends on your priorities, as you can't have everything.
Bilstein suspension setups are primarily oriented toward track use. Ohlins, on the other hand, offers a more balanced approach. Lastly, KW provides a wide range of options, catering to anything from street to race car applications and everything in between.
05-16-2023, 02:43 PM | #12 | |
Rep 31
What is the 5-22 kit? |
05-16-2023, 02:57 PM | #13 |
3128
Rep 4,378
05-16-2023, 02:59 PM | #14 |
Rep 1,125
I just don't wanna rub
05-16-2023, 04:19 PM | #15 |
Rep 1,433
Might be a bit outside your budget, but check out the DDC suspension line from KW (if you're not familiar). They are coilovers that allow you to adjust the damper stiffness from the cabin. If your vehicle has the M Sport suspension from the factory, it's plug-and-play. Otherwise, they have a version with a controller. If not, I'd go with Ohlins; however, they didn't offer an xDrive version when I was looking years earlier (F31).
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
05-16-2023, 04:32 PM | #16 | |
Rep 1,125
eleven11376.00 |
05-16-2023, 08:07 PM | #17 |
3128
Rep 4,378
245/40/18@ET30+275/35/18@ET40 won't rub
235/45/18@ET30+265/40/18@ET40 even though it's slightly taller, won't rub due to stretch here is a lowered F30 with 245/40/18 on 18x9 ET29 front + 275/35/18 on 18x10 ET40 rear, OEM 513M https://f30.bimmerpost.com/forums/sh....php?t=1445526 255/40/18+285/35/18, unlikely to rub, but front could possibly graze fenderwell liner at full lock and rear could possibly graze fenderlip under compression. since it is not 100%, i'll eliminate that combo out. |
05-16-2023, 08:16 PM | #18 | |
Rep 1,125
05-16-2023, 08:20 PM | #19 | |
3128
Rep 4,378
for your vehicle F32(440i), 18-22 is correct. it depends on the weight over the axles. F36x has more weight over the rear than F32x https://www.eibachshop.com/index.php...gs-bmw-4-coupe |
mobbinthesteez22.50 |
05-16-2023, 08:41 PM | #20 | |
3128
Rep 4,378
https://f30.bimmerpost.com/forums/sh...-5RS+black+F36 N8_Fury and two other members with F36x and 235/40/19(26.4")@et29/30 front+265/35/19(26.3")@et40 rear have grazed the fenderwell liner/tab at full-lock. they were all unlowered. lowering the car adds slightly more negative camber and the tire position moves up in the well, increasing the distance at the closest point of contact to the fenderwell liner at full lock. this seems to eliminate any rub. . Last edited by alohasurftoad; 05-16-2023 at 08:51 PM.. |
05-16-2023, 10:58 PM | #21 |
Rep 806
I've never had rubbing with 18x8.5 et38 245/40/18 square winter and 19x8.5 et33 245/35/19 summer. Lowered on kw v3 which is a great kit, though a bit stiff for normal dd. It's low but not slammed, I would say perfect. The travel on the v3s is excellent, it soaks up big changes in the surface really really well. I don't hit things and have bad noises, I have to be careful and go slower over bad things, but really no problem. If you're scraping and having noises all the time you're too low or running wheels that don't fit.
After removing the rear shocks 3 times to get the adjustment right the handling is good, nice and neutral just a bunch of slop and body roll. I am considering the mono ball, but really need sway bars first. I don't need camber plates but if certain wheels I wanted to run needed a little camber to fit, I'd be open to the milway kit. I currently have a 3mm spacer up front to keep it away from the strut. With the new wheels I think I will end up with a 2mm all around. Adjustable sway bar end links helped as well. I had the Bilstein b16 and they were good too but maybe a notch stiffer and I couldn't get the front low enough. I still have them actually, the one shock rod needs repaired, Bilstein said said no problem, send it in, and I just never did. At this point I should just sell them super cheap, dm me. Sadly ohilins didn't make a kit for the xdrive at the time. I forget, but I think you could run the rwd kit with slight modification. Maybe someone remembers the difference. The street comforts are probably a great choice Last edited by B58 parts; 05-17-2023 at 01:12 AM.. |
alohasurftoad3127.50 Boostedphil698452.50 |
05-16-2023, 11:30 PM | #22 |
562
Rep 1,502
Drives: F36 435xd
Hi there
Lowered on KW DDC’s Wheels are front 8,5”, 235/40/19 ET35 and rear 9,5”, 265/35/19 ET40. Don’t know how it drives yet, picking up from the shop this afternoon
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
