05-10-2023, 07:55 PM | #1 |
189
Rep 424
f80/82 brake upgrade coding
Going to do a brake upgrade soon to 370/345 on my F36.
Has anyone had the dealer code the m perf brakes and knows how much that runs - ballpark? Or if there’s a reputable remote service that does this? I do have ENET cable but haven’t found a solid step by step guide to be comfortable enough to do DIY it.
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
05-11-2023, 12:56 PM | #2 |
Rep 306
I've been told the Bimmergeeks ProTool app can code this, once by a knowledgeable post in the coding section and once by personal outreach to Bimmergeeks directly.
There are remote coding services but ProTool interested me because I don't have a laptop. |
obzen189.00 |
05-11-2023, 01:27 PM | #3 |
189
Rep 424
Thanks for the pointer. I contacted them to see how much it would cost to do it remotely. The PotTool app seems to be available on Google store only, buying a license might run me the same price the dealer would charge.
Btw I called the dealer and they asked for $215 for the brake coding in case someone is wondering.
_ObiJon207.50 |
05-11-2023, 02:49 PM | #4 |
189
Rep 424
They just responded and said they don’t do remote coding unless I have the tool. Might have to bite it and take it in to the stealer. Unless I find someone else.
05-11-2023, 07:28 PM | #5 |
Rep 893
I believe you do not need to recode the brake bias for upgrading to either the MP brakes or F80 370mm brakes if your car came with 340mm front Brembos..
05-11-2023, 07:30 PM | #6 |
189
Rep 424
There are mixed reviews opinions on it, I’ve heard it stiffens the feel of the pedal. I’ll run without it post install and determine if I need it or not
05-11-2023, 08:09 PM | #7 |
Rep 103
Installed the F80 front kit this week and the result was better braking with no recode. I don't think it is needed. I will install the Endless 650 fluid in a week or too for better line pressure. Car stops very well now.
05-11-2023, 08:11 PM | #8 |
189
Rep 424
Thanks for the feedback, I’ll run without the recode for a while to see how it is. Just curious what kind of rotors and pads did you end up with?
05-11-2023, 10:01 PM | #9 | |
Rep 893
Now if one didn’t have the factory 340s already they’d need to code to get the proper bias… |
05-11-2023, 10:07 PM | #10 |
189
Rep 424
According to you I won’t need to then since I have grey brembo 340 mm front and single Bosch 1 piston rear
05-12-2023, 12:01 AM | #11 |
Rep 806
I don't think that's true at all. When I installed the m performance kit it was clear to code the spbr option.
"Include SPBR option in the ho-wort folder, recode vo to VCm" If you search around for spbr and ho-wort you'll find it. |
obzen189.00 |
05-12-2023, 06:31 AM | #12 |
189
Rep 424
Did you code it yourself and what brakes did you have before m performance?
05-12-2023, 06:48 AM | #13 |
Rep 806
Yes I did it myself. I had the gray brakes the big 340 ones, changed to the bigger yellow m performance ones.
You have to add the sport brake option. Get esys and the cable, it's all really easy. After coding it, with the laptop still connected, I fired up ista and used the service function to activate the ABS pump and get a good bleed, since the lines were open. You have to do that too. Yes you need a computer to bleed brakes, if you introduce air into the system. I posted about it if this section, if you search a bit for spbr ho-wort you'll find a lot about it |
05-12-2023, 06:50 AM | #14 |
189
Rep 424
I’ve got the cable just need esys. Would you want to assist ? I’ll gladly Venmo you ha
05-12-2023, 06:57 AM | #15 |
Rep 806
When you buy your car there's a build sheet that lists all the options you have. This is coded into the car as the vo, vehicle order, and it drives how things behave. Sbpr is the option for the sport brakes, if you got the track package with the blue brakes you would have that on your VO. So it would be logical to keep it in sync. And since you reflash the DSC module, I would guess it affects how the ABS computer behaves.
I mean you don't have to do it probably, but since you spent over 2k on the brakes you might as well take the 5 minutes and get the computer right so you don't have any weird issues and it's working as it should. All of the DIY posts I read all of them said to do the coding when you're done |
obzen189.00 |
05-12-2023, 07:01 AM | #16 | |
189
Rep 424
05-12-2023, 10:08 AM | #17 |
Car Hypochondriac
335
Rep 903
Drives: 2014 335i M-Sport Estoril Blue
The recode helps the pedal performance and I highly recommend you do it. As said above, it's a very simple process in esys. I believe you can do it in ISTA as well, it should be under retrofits.
obzen189.00 |
05-25-2023, 06:27 AM | #18 |
189
Rep 424
Update:
Got the brakes fitted yesterday and I’m super happy with the setup. Looks amazing. I am not 100% sold on the brake pedal feel though. I think I may have to do the coding. It feels a bit soft if I have to be honest. Not sure if it’s because I already expected it and if it’s placebo. Again if anyone is willing to help code remotely I’ll compensate I have an enet cable and a MAC with a windows VM along with a rj45 adapter.
05-30-2023, 10:52 AM | #20 | |
Rep 28
05-30-2023, 11:19 AM | #21 | |
189
Rep 424
BTW which rotors did you go with ? Slotted/dimpled? If so have you noticed the ticking sound when you drive with window down next to a wall / barrier / objects? I came to find out that the the M perf brakes are known for this, blah.
05-30-2023, 11:26 AM | #22 | |
Rep 28
