2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Retrofit OEM alarm
      03-17-2023, 07:02 AM   #1
jackev
Portugal
Drives: BMW 520D F11
Retrofit OEM alarm
I retrofitted the alarm on my 2015 BMW F11 car but now I have a problem detecting the ECU, when I run ISTA it shows ECU FZD
But when I run esys the ECU FZD does not appear
attachment: error in ISTA
does anyone know the solution
thanks
      03-18-2023, 12:19 AM   #2
M_Bimmer
M_Bimmer's Avatar
588
Drives: G12 B7, G07 XB7, F02 B7, 991.1
Can you provide a bit more information?
Did you change the FZD (A21) from a basic to a "high version"?
Did you install the alarm horn (H1) in the right rear bumper area?
Did you run the LIN Bus wire from the H1 to the FZD?
Did you code S145A option into your FA?
What does ISTA list as your error code for the FZD module?
      03-20-2023, 11:36 AM   #3
jackev
Portugal
Yes
No, I have installed Alarm System Retrofit
No, I followed the instructions I attached for the installation
I used the original cables that come with the retrofit
No, I code S302 in FA
attached ISTA_ERROR
thanks
File Type: pdf 65752448363-Installation-instructions.pdf (1.05 MB, 121 views)
      03-20-2023, 09:56 PM   #4
M_Bimmer
M_Bimmer's Avatar
588
Originally Posted by jackev View Post
thanks
The diagram on page 9 of your installation manual doesn't look like your retrofitted alarm interfaces the FZD module, only the CAS.
This means your issue with the FZD in ISTA, is independent of your alarm wiring.
On page 13 of the installation manual, it does show removal of your FZD module to route your alarm wire to your rearview mirror.
I would recommend that if you did pull the FZD module, to remove it, and try to reseat all the connectors. It looks like the connector that has the bus wires isn't plugged all the way in.
      03-22-2023, 06:33 PM   #5
jackev
Portugal
hello M_Bimmer
I only had the opportunity today to remove the FDZ module and I verified that the A21*2B connector does not have the CAN wires that connect pins 9 and 10.
I will have to make this connection between connector A21*2B and connector A16*1B.
5post
