BMW M3 and M4 - The Icons
Technical Sections Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      02-19-2023, 04:22 AM   #1
M_174
Drives: M4C RWD 2021
M4C not accelerating and smoke
Hi everyone,
I had my car for about 6 months and I always drive it fast on good highway roads outside the city. Last weekend, my car started suddenly to cut power at RPM higher than 5000 and if I kept my foot on the paddle when it cuts power grey smoke started to come out of the exhaust I can see it in the mirror!
I was using pump fuel 95 about half tank when this happened, I refilled the tank when this happened and tried again, same issue happened again.
I drove my car back home, on low RPM/ normal city driving the car is totally fine.
I have an appointment at BMW next week as the car is under warrranty but I wanted to get your opinion on what this issue could be and if anyone faced something similar.
It feels like something fuel related as the car drives normally on lower rpm.
      02-19-2023, 06:16 AM   #2
SE7EN335
Drives: 2022 M3 XDrive, 2023 IX M60
Originally Posted by M_174 View Post
Hi everyone,
It sounds like the car is detonating at higher rpm due to insufficient octane. Your DME would have knock sensors to detect those detonations (knocks) and be constantly pulling timing, thus the cutting of power that you are feeling.
And when you say pump 95? Do you mean 95 AKI or 95 RON? 95 RON and driving it hard like you stole it wouldn't go down well.
2022 M3 XDrive - Full Race Turbos - BMC Filters - MAD Catless downpipes - MAD single midpipe - BM3 Flex Fuel Kit - Paul Johnson Flex Fuel - XHP - MPHAS - EBC Bluestuff - PS4S
2023 IX M60
2018 Lotus Exige Sport 410 - Harrop TVS1900 Supercharger - HKS Intake - Larini Headers - Simply Sports Cars Custom Tune - Ohlins TTX - Ferodo DS3.12 - Yokohoma AD09
      02-19-2023, 08:26 AM   #3
M_174
In my country we have 91 and 95 options only, I am not sure RON or AKI my car is stock and this is the fuel recommended by the dealership.
The cutting of power is accompanied by huge smoke.
Is it safe to drive the car to the dealership at low RPM? Or should I have it trasportrd to dealership?
      02-19-2023, 09:32 AM   #4
SE7EN335
Just did a search for Saudi Arabia fuel and it looks like you guys only have 91 and 95 RON.
I personally wouldn't drive it hard on 95 RON, as the DME would constantly pull timing. From personal experience, I have previously filled up on my F80 M3 from empty using 95 RON at a remote location where they didn't have 98 RON at all. As soon as I pulled out of the fuel station onto the highway, I could feel a substantial decrease in power. I imagine it would be the same on the G8X.
I think it is safe to drive the car to the dealership as long as you avoid high rpms, which is where the detonation occurs.
Do you have any octane booster in your country? I personally would throw in a bottle of octane booster on a full tank and see if the problem disappears. If it does then it is because of low octane.
2023 IX M60
      02-19-2023, 10:01 AM   #5
M_174
Yes we do, octane booster and pure octane are both available. I’ll try it out and see.
I am in Saudi and you would imagine we should have the best fuel in the world but unfortunately it’s not the case.
      02-21-2023, 03:28 AM   #6
windnsea00
447
Drives: M2 CS
95 RON is close to 91 AKI, the highest we get in California, minus the rare and very expensive 100 AKI racing gas.
2020 M2 CS AW 6-spd
Previous M Cars: M2C, M2, F80 M3, E46 M3, Z3M Coupe, E36 M3...and some other fun rides.
zero213253.00
      02-21-2023, 06:04 AM   #7
M_174
I had the car checked in a workshop and it seems there is an issue with high pressure fuel pump.
Speaking with local BMW customers another one also M4 G82 is facing a similar issue but he got an alarm and car is restricted at 3000 rpm.
Anyone here faced similar problem? I don’t see many reports on it.
      02-21-2023, 06:09 AM   #8
SE7EN335
Haven't heard of any HPFP issues happening on a stock tune S58 or even B58. Seems very strange...
I'm running on JB4 Map 4 E35 mix with no issues on the HPFP. My friend is running on custom E85 flash tune and also no HPFP issues.
Did you try the octane booster or filling up with a few gallons of E85 to see if the problem still persist?
2023 IX M60
      02-21-2023, 06:15 AM   #9
M_174
Yes I added octane booster, the amount of smoke reduced significantly but the power still cuts.. it feels as if traction control is interfering
I also tried with traction fully off just to check if it is a traction issue but no change
      02-21-2023, 06:34 AM   #10
SE7EN335
Gray smoke out of exhaust usually indicates fuelling problems. If there is less gray smoke, the extra octane definitely helped with that.
I would get it checked out by a BMW dealer who will be able to check out any fault codes or even shadow fault codes on the car. And they can log the HPFP and LPFP psi, and injector fuel trims on full throttle to see if it is genuinely those components that are failing
2023 IX M60
      02-21-2023, 06:38 AM   #11
M_174
Definitely, I am just asking around while waiting for my appointment next week.. thanks all for the help, appreciated
SE7EN335330.00
      03-01-2023, 10:19 AM   #12
M_174
Went to the dealership they checked the car and they said the catylitic converter need replacement.
There is no damage from the outside but maybe something went wrong inside!
They ordered the parts from Germany and will have it installed in couple of weeks, apparently the car is not safe to drive in this condition.
Ximian1919.00
SE7EN335330.00
      03-03-2023, 09:34 PM   #13
Indo Rider
Drives: 135
This thread describes similar issue only at high rpm, turned out to be the HPFP in the end.
https://g80.bimmerpost.com/forums/sh....php?t=1958719
SE7EN335330.00
M_1747.50
      03-17-2023, 04:37 PM   #14
AHall
982
Drives: 1993 Nissan 240sx
Unless the catalytic converter was defective when the car was built, they have not identified the cause of your problem. Something has caused the catalytic converter to become defective. Excessive exhaust temperatures perhaps. If they have not identified the cause you will likely be back in the same boat. Especially the way you drive.
g80
