01-17-2023, 01:45 AM | #1 |
Rep 82
F30 335i coding US to ECE
Hello everyone,
I have been trying to code my BMW F30 335i from US parameters to ECE ones. Do you know what I need to change in the VO in order to change from US to EU and which modules need to be coded with VO values? As per my research: 1. 697->698 (DVD Area code 1 -> 2) 2. 230 (Eu specific aditional contents) Not sure what this does and if it necessary 3. 876 -> 874 (Radio frequency 415 -> 434) I catch most of the EU stations with 415 frequency as it is now 4. 645 (Us radio control) should I remove this? 5. 801 (German version) Does that mean default EU and is it required? FDL Code HU_CIC/NBT Module: RADIO_COUNTRY = ece FM_DEEMPHASIS = 50us ANZEIGE_FREQ = nicht_aktiv Thanks in advance. |
01-18-2023, 12:11 PM | #2 |
582
Rep 2,047
You can also include changing the typecode to change the region. You can remove 801 when using an ECE typecode since the typecode will automatically change region to ECE. Use NCD CAFD tool to see the modules affected by the options added. Main module will be HU
01-18-2023, 04:27 PM | #4 |
Rep 82
Is it possible to edit the FA in BimmerUtility and get which NCD files are for this FA? Then compare them to my current NCD files. Like doing the comapre offline, since I would first like check what will be changed coding it. Or you mean to:
1. Read CAFD files with the current FA and save them 2. Write the new FA file to the car without coding the modules 3. Read The CAFD files from the new FA and save them 4. Compare the two versions of the CAFD files Just Writing FA to the car without coding the modules, should not change anything, right? |
01-19-2023, 12:11 AM | #6 |
582
Rep 2,047
01-19-2023, 01:42 AM | #7 |
Rep 82
I think I found one as well. Mine is A393. Found that A395 is EU. How this will afffect the car? Because I have xHP for my original typecode and I am not sure I want to mess with the typecode anyway if the VO coding does the same thing.
01-19-2023, 03:24 PM | #9 |
Rep 82
01-20-2023, 12:30 AM | #10 |
582
Rep 2,047
Since you have Xhp i cannot know if it will affects the software. Maybe they read the typecode from the VIN or from the FA. I doubt it will affect since the typecode is similar only region is different. Either way it not necessary to write fa to vcm. You can just load the FA and active it and code. That will code according to the fa loaded. You dont need to write fa to vcm.
If you want to avoid modifying the fa use coding verification in esys to create cafd using the FA and modified FA then compare the cafds created. From that you can see the difference and do the coding manually. |
01-20-2023, 01:37 AM | #11 |
Rep 82
I get it. I tried to generate the CAFDs based on the FAs without hooking Esys to the car, but in Coding-verification it showed me all of the available CAFDs and not the ones for the FAs I have loaded. Should I be hooked to the car to get CAFDs only for my FAs?
02-01-2023, 03:34 PM | #13 |
Rep 82
TheNine90 Okay, I tried what you suggested, but it didn't succeed. I wrote the new FA to the car and went with coding the CIC and CMB_MEDIA modules. Everything was coded, except when I added the 801 (German version). Then it said that it conflicts with some other value and that multiple values are trying to be written to a parameter.
02-01-2023, 04:52 PM | #14 |
Rep 82
I managed to solve this problem by changing the typecode in the FA as well to an ECE one. Then compared some of the CAFDs and noticed that there is even a change in the DME from US to ECE. Am I supposed to code all of the modules(including the DME), except the ASCM and that won’t bug something?
02-02-2023, 12:36 AM | #16 |
Rep 82
But do you know, what will happen if I code all of them? Will it be bad? Like removing the panic alarm(strange) adding some features for the FLA, headlights?
And will writing a different typecode to the car affect it, or I only load new FA in Esys and just code modules? Thanks |
02-02-2023, 01:14 AM | #17 |
582
Rep 2,047
If its the same typecode but different region it wont affect much. Only some options maybe deactivated and some activated. Best it to compare both cafds and see what changes.
When you change region you only code things that you see that are different. Like headunit, maps. If it doesnt affect do not code it. Some coding may require hardware component to work. Like fla need the front camera. You can look for various retrofit guide and see whats needed. |
02-02-2023, 02:35 AM | #18 |
Rep 82
I see. So you are telling me to just code the modules that I can visually see and don’t touch the others. I will take my time to compare every CAFD and maybe I will replace some of the US options to the ECE ones, while leave the others as US.
02-02-2023, 03:23 AM | #19 |
582
Rep 2,047
Something doesnt matter like coding DME, CAS, seat modules, FZD. When converting look for specific items you want to change and code them manually. If you VO code using another region some functions will be affected. The car is built for another region you cannot change everything software side, the hardware might slightly be different. So best option is to compare and change code manually only the necessary.
