01-15-2023, 03:09 PM | #1 |
Rep 82
After OTA "upgrade" persistent "Acoustic Pedestrian Protection" warning message
I let the system upgrade to the new software version and now have a persistent "Acoustic Pedestrian Protection warning failure" message.
I did install a Bimmer-Tech Match PP86DSP amplifier in late '21. The only thing that I can think of that might contribute to the error message. I don't even recall hearing the pedestrian warning before the amp install, so maybe there is an issue and the new software update is just now flagging this problem. Ideas? OK: After some more research and searching of the forums, this appears to be a known issue and Bimmer-tech has a fix for it. Last edited by RC_Hund; 01-16-2023 at 02:25 PM.. |
01-15-2023, 05:31 PM | #2 |
13628
Rep 20,255
We have had another member report this issue and they installed an aftermarket amp also.
https://g05.bimmerpost.com/forums/sh...1#post29734901
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2024.40
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 |
01-16-2023, 10:37 AM | #3 |
Rep 75
Drives: 2022 X5 4.5e
Same problem here
Bimmertech amp as well. I am scheduling appointment w/ BMW service, see what they can do.
TE Moore
01-16-2023, 11:11 AM | #4 |
Unapologetic Tool Hoarder
736
Rep 966
If it's interfering with the CAN bus messaging and throwing errors, I'm pretty sure the answer is going to be "Disconnect the aftermarket accessory causing the issue". You're probably better off contacting Bimmertech and seeing if they can update the firmware on the amp for compatibility.
RC_Hund61.00 |
01-16-2023, 12:56 PM | #6 |
Rep 82
Found a thread from last year about people having this issue with the bimmer-tech amp and that bimmer-tech has a new cable which they can send out.
https://g05.bimmerpost.com/forums/sh...ght=focal+subs |
weinerbarn735.50 |
01-16-2023, 01:12 PM | #7 | |
Rep 75
TE Moore
RC_Hund61.00 |
01-19-2023, 05:56 PM | #10 |
Rep 75
Bimmertech sending revised connector
I have a 4.5. and get the message. Bimmertech is sending a new connector (26 wires). The original has 22, apparently fine except for the 4.5e.
TE Moore
01-30-2023, 11:29 AM | #11 |
Rep 82
Received my updated harness and installed yesterday. Took about half an hour total because I wanted to check on the input sensitivity setting.
See if it could go louder... Turns out I had it already set to max. |
