12-26-2022, 03:08 PM | #1 |
Rep 165
what jack pad is needed?
New to BMW, I see many jack pad adapters available with a rectangular top to work with BMWs. I haven't found one on Amazon that lists the G80. Is there a certain size needed?
Guess this will apply to Jack stand adapters as well. Thanks |
12-26-2022, 04:46 PM | #2 |
5403
Rep 2,030
Drives: G80 M3 Competition
I have used an adapter before on my G80, but they made me a little uneasy as the pad was smooth with no traction. I stopped using those and now solely use a Schwaben jack (flat rubber jack pad) and ESCO jack stands (some of the only ones on the market with flat rubber pads). A set of these jack stands and the Schwaben jack will be all you need.
12-26-2022, 06:21 PM | #4 |
5403
Rep 2,030
The adapters are most definitely not required. I have used only my jack pad and the pad on my ESCO stands quite a bit, and the BMW mounts are still in great condition. I prefer this way, as the BMW mounts grip the pads really well.
AWDSOME629.50 |
12-30-2022, 08:41 AM | #6 |
3398
Rep 6,589
Drives: BMW
01-04-2023, 11:38 AM | #7 |
Rep 251
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
These fit inside the jack slots on the car |
M4Tejas788.00 |
01-05-2023, 05:50 PM | #8 |
Rep 139
How do the rubber pads on the ESCOs hold up? I just got a set of the harbor freight/Daytona ones (ESCO replica) and they seem to deform under pressure
FISH225402.50 |
01-05-2023, 05:58 PM | #9 |
2563
Rep 1,927
You're supposed to use a jack pad that everyone above is suggesting, as for your new stands i'd get a replacement asap, that looks faulty.
01-05-2023, 07:02 PM | #10 | |
5403
Rep 2,030
And I didn’t know there were replica ESCOs, nice! I might pick up a set. |
01-14-2023, 10:06 PM | #11 | |
Rep 1,369
I do use the jack pad adapter from bms if I just have to jack up one side for some reason, otherwise I use the center jack point and then the esco jack pads. |
01-29-2023, 10:41 PM | #12 |
Rep 85
Drives: 2023 M3C
I use the BMS adapters also on all 4 jack points and my Quickjack BL-6000 XLT lift. If I'm under the car then ESCO jack stands.
https://burgertuning.com/products/bm...ck-pad-adapter |
