11-06-2022, 03:05 PM | #1 |
Rep 78
What cleaner to put in a a bissel spot cleaning machine
What can i use to clean the carpets that wont create any stains? Oxyclean is a nogo. Need something asap that is readily available generally locally.
11-06-2022, 06:09 PM | #2 |
Rep 111
I would think that any supermarket or big box home improvement store would have jugs of cleaning fluids specifically made for powered carpet cleaners. Likely a Bissel product, but if not, a similar and compatible product.
Of course, assuming you have local access to a supermarket or Home Depot. Frank |
11-06-2022, 06:19 PM | #3 | |
Rep 78
12-27-2022, 07:22 AM | #4 |
Rep 1
Do not use laundry or dish soap. They are designed to create high level suds while the Bisell solution or any other carpet and upholstery cleaner are formulated for low suds. A high suds soap will be useless in cleaning, a mess to work with and will fill the solution tank with foam requiring you to refill very frequently. But the worst part is that the high suds soap will leave a residue that will foam every time they are exposed to any water despite extraction. It is a case of just don't do it. routerlogin
watch IPL Last edited by byetata276; 03-04-2023 at 02:44 AM.. |
