10-26-2022, 02:04 PM | #1 |
2930
Rep 21,739
▀▄ eas | Adro Carbon fiber collection G80M3 G82 M4 - Now Shipping
Adro G80 M3 and G82 M4 Carbon Fiber Collection EXCLUSIVELY DESIGNED FOR BMW M3/M4 G8X Reimagined by ADRO A design that inspires boldness. The ADRO BMW M4 facelift reinvents the newest generation of the BMW M4 with a functional dual kidney grill, lightened materials, and improved aerodynamics. BOLDNESS IN DESIGN DESIGNED AS IT SHOULD BE The BMW M3/M4 G8X facelift kit by ADRO optimizes the design elements of the newest generation of BMW M3/4 through purposeful changes. No stone was left unturned as the ADRO design team took to the BMW M3/M4 front bumper. With every design element featured on the vehicle analyzed, our designers worked carefully with the aerodynamicists to create an improved look that embodies the boldness we’ve come to know from BMW. OEM FITMENT THE WAY IT SHOULD BE ADRO M3/M4 facelift kit ensures all sensors, cameras, and systems within the new generation of this chassis are maintained along with factory mounting positions. The final result is a kit that rivals the original quality from the BMW factory with a design the chassis was meant for. MAKING IT BETTER WITH INCREASED DOWNFORCE AND PURPOSEFUL DESIGN Through redesign comes opportunity. The ADRO M3/M4 facelift kit features optional components like our wet carbon fiber front lip. Additionally, our remaining components come as prepreg carbon fiber such as the side skirts, rear diffuser, and swan neck wing. All components and design elements are built to ensure fitment & performance improvement across a wide range of applications. Bumper & Carbon Fiber Component Compatibility: 2021-2023 BMW M4 Standard 2021-2023 BMW M4 Competition 2023 BMW M4 CSL 2021-2023 BMW M3 Standard 2021-2023 BMW M3 Competition KEEP IT LIGHT WITH PREPREG CARBON FIBER COMPONENTS Through innovation and internal expectations, we are also introducing optional prepreg carbon fiber components to complement the ADRO M3/M4 facelift kit to ensure your vehicle's presence is demanded. Each side skirt, wing, and diffuser is manufactured utilizing a prepreg carbon fiber process to ensure an exact amount of resin and carbon fiber is used to maximize structural integrity and weight reduction seamlessly. The front lip is manufactured utilizing wet carbon to ensure flexibility is maintained with a component that can experience the most abuse from the road. Full High Resolution shoot can be seen Here Adro - BMW G8X M3/M4 Facelift Carbon Fiber Front Bumper PRESENCE DEMANDED Everything it should be, and more. The redesigned front of the BMW M3/M4 features a more aggressive crease design and slope with a reduced kidney grill size to rightsize the OEM design elements. STAY CONTROLLED Below the ADRO front bumper features an all new wet carbon fiber lip that embodies aggressive design elements while further optimizing airflow for improved downforce performance. Love it or hate it, the G8X generation of the BMW 3 series is here to stay. Take that new look to a whole new level with the ADRO carbon fiber front bumper. This front bumper is made from 100% real carbon fiber for a lighter and stronger construction. This front bumper kit will transform the look of any G8X M3 or M4 and has the fit and finish of an OEM part. Complete the front fascia with our front lip made from real handcrafted carbon fiber and shaped to perfectly accent the redesigned ADRO front bumper. ADRO M3/M4 facelift kit ensures all sensors, cameras, and systems within the new generation of this chassis are maintained along with factory mounting positions. The final result is a kit that rivals the original quality from the BMW factory with a design the chassis was meant for. Models Supported - BMW G80 M3 - BMW G82 M4 Adro - BMW G8X M3/M4 Carbon Fiber Side Skirts BRING IT IN Skirts: A design that properly connects the design elements from the front to the rear, the optional carbon fiber side skirts bring the necessary look to demand presence from any angle. Each skirt is manufactured utilizing our proprietary prepreg carbon fiber process and is additionally optimized for maximum downforce through the rear winglets. Often overlooked, side skirts can be the final touch that can pull an entire build together. The ADRO carbon fiber side skirt kit is designed to accent the factory body of the G8X M3/M4 while flowing perfectly with the other carbon fiber pieces available for this platform. Featuring real carbon fiber construction and a design that was created to look great and increase downforce, this side skirt kit is everything the G8X needed and more. Models Supported - BMW G80 M3 - BMW G82 M4 Adro - BMW G8X M3/M4 Carbon Fiber Front Lip Make a statement the ADRO carbon fiber front lip kit for the newest generation of the BMW M3 and M4. This front lip is made from real handcrafted carbon fiber and was shaped to perfectly accent the redesigned front bumper for this generation of the M3 and M4. Lighter, stronger, and more aerodynamic than the standard front lip, the ADRO carbon lip will not only make your car look far more aggressive but will also aid in downforce. Note: Compatible with Adro Carbon Fiber Front Bumper only! Models Supported - BMW G80 M3 - BMW G82 M4 Adro - BMW G82 M4 Carbon Fiber Swan Neck Wing MORE FORCE Wing: The purpose-built wing cuts through the air with less resistance than a typical wing design due to the upright engineering. Prepreg carbon fiber ensures that the weight savings is maximized while additionally offering over X pounds of downforce at Y miles per hour. Increase downforce while completely transforming the rear end of the G82 M4 with the ADRO carbon fiber rear spoiler. This hand-crafted carbon fiber spoiler finds the perfect balance between function and form while staying as lightweight as possible. With clean and simple installation and an OEM fit and finish, the ADRO carbon fiber rear spoiler is the perfect match for any G82 M4. Models Supported - BMW G82 M4 Adro - BMW G8X M3/M4 Rear Carbon Fiber Diffuser CUT THROUGH Diffuser: Completing the look through sharpened rear winglets, our prepreg carbon fiber diffuser with a featured rain-light helps evacuate the air underneath the car while keeping you visible in inclement track conditions. Make that quad exhaust pop even more with the ADRO carbon fiber rear diffuser for the G8X BMW M3/M4. Featuring a more aggressive design, carefully engineered aero, and a beautiful carbon fiber finish, this is by far the highest quality and most aggressive rear diffuser currently available for the G8X platform. Models Supported - BMW G80 M3 - BMW G82 M4 Ordering: Phone: You can reach us directly by calling 866.669.0705 x 31 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday - 9AM-12PM PST Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell. Contact Info: Phone: 866.669.0705 x31 Email: kevin@europeanautosource.com Website: http://www.europeanautosource.com Feel free to contact me via PM, email, or phone if you have any questions
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 01-26-2023 at 04:02 PM.. |
11-14-2022, 06:22 PM | #2 |
2930
Rep 21,739
Thanks for the inquiries
Pre orders started for Adro carbon fiber kits
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
11-16-2022, 01:01 PM | #3 |
2930
Rep 21,739
Some more shots of the Adro complete package
12-01-2022, 04:32 PM | #4 |
2930
Rep 21,739
Compliment your M3/M3 with Adro carbon fiber
01-06-2023, 04:15 PM | #5 |
8250
Rep 18,839
Drives: BMW
Last call for pre-orders and pricing, new pricing effective 1/16/23. Get those last minute order in now!
01-08-2023, 07:06 PM | #7 |
1112
Rep 3,261
hows the rear visibility with the wing?
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
01-09-2023, 02:26 PM | #8 |
2930
Rep 21,739
PM Sent
Will try to get some pictures as soon as one is installed. I anticipate it to be similar to the M performance spoiler in terms of visibility.
01-26-2023, 03:58 PM | #9 |
2930
Rep 21,739
Thanks for the inquires
Adro G80/82 parts no shipping PM today to get yours
TurboSid1112.00 |
02-16-2023, 06:16 PM | #10 |
2930
Rep 21,739
Adro carbon fiber kits ready to ship
03-15-2023, 07:17 PM | #11 |
8250
Rep 18,839
Drives: BMW
03-29-2023, 05:47 PM | #12 |
2930
Rep 21,739
Adro front bumpers in stock
04-05-2023, 06:18 PM | #13 |
8250
Rep 18,839
Drives: BMW
Adro kits back in stock! PM to get yours today!
04-10-2023, 06:57 PM | #14 |
8250
Rep 18,839
Drives: BMW
05-15-2023, 06:09 PM | #15 |
2930
Rep 21,739
Adro carbon ready to ship PM today to get yours
06-06-2023, 03:39 PM | #16 |
8250
Rep 18,839
Drives: BMW
Adro kits in stock, get yours today!
07-06-2023, 04:07 PM | #17 |
2930
Rep 21,739
Adro kits in stock and ready to ship
08-02-2023, 06:48 PM | #18 |
8250
Rep 18,839
Drives: BMW
1 Adro Kit for G80 M3 up for grabs in stock. Once sold, new orders will be backordered until October.
01-10-2024, 06:19 PM | #19 |
2930
Rep 21,739
Adro hood now available for your G80/G82
PM to get yours https://europeanautosource.com/produ...-bmw-g8x-m3-m4
02-12-2024, 05:37 PM | #21 |
2930
Rep 21,739
PM sent
03-25-2024, 06:13 PM | #22 |
2930
Rep 21,739
Adro carbon fiber kit in stock and ready to ship
