08-26-2022, 12:40 PM | #1 |
Rep 294
Drives: 2013 Focus ST, 2022 M3Cx
Suspension shipping blocks - what's the point?
Rather than hijack another thread, thought I would start a new one to ask...what are the point of the dreaded suspension shipping blocks? It continues to come up from time to time, dealer get sloppy and people taking delivery of cars with them still installed, driving around wondering what on earth is the matter with their brand new car.
So...what does this protect against? Excess suspension travel while the car is on a truck or train, going over some bad bump or whatever? I guess it might be better to be slamming in to what look like semi-rigid plastic blocks rather than hitting the suspension travel limits. |
08-26-2022, 12:45 PM | #2 | |
1919
Rep 2,138
You won't believe how tight the cars are parked against each other inside the vessel. |
08-26-2022, 12:51 PM | #3 | |
Rep 1,241
3/19/22: Deposit placed on MY2023 Skyscraper Grey M3 Comp xDrive / 6/08/22: Dealer order placed - Status 047 / 6/25/22: Added Full Leather / 8/05/22: Received Allocation & Added Personal eSIM 5G / 09/18/22: Asked Dealership to Add M Drive Professional to My Build and They Canceled My Order
08-27-2022, 09:40 AM | #4 |
Rep 388
If you say the car spends 10 days/240 hours on the ocean (and may be longer) of continuous input into the suspension, that would be close to 10,000 miles of road use at 40mph.
Spring rates and damper settings are obviously tuned for road usage. Inputs on a boat or train are very different in amplitude and frequency, so an ocean trip would be like 10,000 miles of input that the suspension is not optimized for… Blocking the springs reduces spring and damper travel and also (hopefully) avoids bump stop loads. FYI - a number of years ago an OEM had problems with springs failing on a car that comfortably passed all the durability tests. It turned out that transport by train on a certain route induced a spring resonance that caused the failure.
TJR
10
forcefed2572.50 Rux645.00 chicagofan0019225.50 vj1233793.00 Capt Canuck704.00 M3ANSPEC393.00 dini_g80188.00 harperium1316.00 peelerec1032.00 Osheatwo206.50 |
08-27-2022, 02:23 PM | #5 |
Rep 617
Drives: Little of this, little of that
My guess is to allow maximum space allowance during transport. Double decker trailers esp have very little height clearance. Suspension travel, if unrestrained, could cause roof damage along with break step issues.
08-28-2022, 08:53 AM | #6 |
13542
Rep 7,001
Drives: 2022 DG/BLk xDrive M4C Wk 34
Definitely used to have a suspension stopping distance for shock travel. If you preload the suspension by strapping the car the shipping deck, you want a consistent tie down for every car.
By tying the cars down without suspension blocks, you would essentially pull the car down to the shipping deck, while simultaneously forcing the wheels outward, in all different directions, ruining the alignment, and then forcing the car to stay in that spot for up to a month. Every car would need an alignment at the port. Not to mention the suspension travel the car also endured during the trip. If you've ever taken a toy car that has any kind of suspension travel, and pushed down on the roof until the bottom of the bottom of the car touched the floor, you'd see all of the wheels bow out in all different directions.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
Rux645.00 androidtopp409.00 |
08-28-2022, 02:23 PM | #7 |
Rep 294
Ahh - having owned only NA built cars in the past - I didn't even think about suspension travel on a boat. Great point, and that YouTube video is pretty demonstrative, wow.
Glad my dealer had its wits about it when it came to removing them...and hopefully everyone else has the same luck. Thanks for the responses, everyone! |
MassComp2123.50 |
01-16-2024, 10:00 PM | #8 |
2163
Rep 4,109
A lot of cars are transported on trains... The drivers are not super gentle with the cars as time is money. Shipping blocks are there to prevent the suspension from diving in when loaded on trains, trucks and ships.
01-17-2024, 08:06 AM | #9 | |
6747
Rep 6,759
01-17-2024, 09:24 AM | #11 | |
6747
Rep 6,759
AKA, likely a bot. |
harperium1316.00 |
