06-02-2022, 05:05 PM | #1 |
Rep 132
Drives: G80
G80 trickle charger convenience setup
Hi guys,
Have a noob question. So I'm trying to set up my CTEK trickle charger with convience access setup on my G80. When I looked the ground post for negative attach point I see both of them are occupied by something else already. So is it okay I just put the negative on one of those post thats being occupied or should I look for other place? Really appreciate for the help. |
06-03-2022, 08:35 AM | #2 |
1916
Rep 2,135
Any ground should be fine.
Where are you routing the connector to? Are you planning on attaching it under the hood somewhere close to the windshield so you don't have to open the hood when charging? |
06-03-2022, 09:35 PM | #3 |
Rep 132
Drives: G80
Yes but the 2 negative ground posts nearby seem already being occupied by some wires. I'm not sure if I can put my negative connector together with those wires.
08-29-2022, 08:01 AM | #4 |
517
Rep 571
Drives: '19 GLA45AMG(his) / '21 X3M40i
Late to the reply, but I put mine to the one closer to the Vin#.
Currently: '19 GLA45AMG grey (his) & '21 X3M40i DGM (hers) w/ JB4@Map1
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior 2014 BE GTR FBO/e85 |
sbgolfer222195.50 |
08-29-2022, 12:05 PM | #5 |
Rep 617
Just wondering why you wouldn't connect directly to the battery in the trunk and keep the connector tucked in under the floorboard when not in use.
08-29-2022, 04:48 PM | #6 |
517
Rep 571
I believe I read/heard that they rather have you connect inside the engine bay so that the circuit can go through a form of ecu as a safety net in case of someone causing a reverse polarity or something stupid like that, while keeping your electronics (which is now, arguably 99% of a BMW) safe.
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior 2014 BE GTR FBO/e85 Last edited by GixY2K; 08-29-2022 at 05:09 PM.. |
08-30-2022, 08:38 AM | #7 | ||
1916
Rep 2,135
08-31-2022, 01:59 AM | #8 | |||
Rep 320
09-03-2022, 04:44 PM | #9 |
Rep 817
This is my setup.
Current - G82 X-Drive in Verde Ermes
SOLD - F82 Sakhir Orange SOLD - G01 X3 White SOLD - E93 Burgundy |
03-04-2023, 02:22 PM | #11 |
Rep 132
Drives: G80
I have noticed if you left your door opend for a period of time the hazard light will automatically turned on. Maybe just a safety feature. Just flip the light switch to turn it off.
03-04-2023, 03:31 PM | #12 | |
Rep 22
I had it connected for an hour and it doesnt turn off. If the light just stays on whats the whole point of keeping it on a trickle charger, right? its just draining the power from the battery all these new cars with technology and random electrical stuff is kinda of annoying hahaha |
03-04-2023, 03:36 PM | #13 | |
Rep 132
Drives: G80
03-04-2023, 05:39 PM | #14 |
Rep 22
03-05-2023, 12:46 AM | #15 |
Rep 22
02-05-2024, 05:33 PM | #16 |
Rep 310
02-05-2024, 05:48 PM | #17 | |
Rep 817
Hope this helps.
02-08-2024, 11:28 AM | #18 |
Rep 1,422
You can absolutely stack rings on a post, as long as you get it good and tight.
Mine is connected directly to the battery. I back into the garage and it would be too much of a pain to connect under the hood. |
Needsdecaf6599.00 |
02-12-2024, 12:01 AM | #19 | |
Rep 310
I have one of these I want to hookup the same way, but how did you get the Positive Red Cap back on after connecting the red cable under there? Seems like the Red cable end is quite thick and prevents the cap from snapping in place, it is made very tight indeed. Thanks |
02-12-2024, 12:03 AM | #20 |
Rep 310
Got it, I tried that, but the red cap can't be put back in place. The cable end is pretty thick and prevents the cap from snapping back in place, it is pretty tightly made.
02-12-2024, 12:11 AM | #21 |
Rep 817
Strange. I did not have the issue. Maybe they change the size. Not sure.
03-25-2024, 05:55 PM | #22 |
Rep 1,277
Drives: 2024 BMW M4 Base
You need to cut the back of the red cap. Don’t worry, it’s a $16 part. Just don’t drop it when trying to reinstall…Don’t ask me how I know.
