05-22-2022, 01:25 PM | #1 |
Rep 29
X3-2013 Drive moderately error
Hi..
2013 BMW X3 XDRIVE28I Sport utility vehicle4 CylindersGas I was driving steep mountains with cruse control 90+ kmps... suddenly i got this notification. Drivetrain malfunction Drive moderately The Engine Control Module on your vehicle detected a transmission or engine issue; drive moderately.... i head winning sound while driving steep mountain . then driven moderate speed.. after engine cool down ... the error code disappeared and that sound also disappeared... do i need to go service centre... to diagnose please let me know Thanks Last edited by apanner; 05-22-2022 at 04:42 PM.. |
05-22-2022, 01:42 PM | #2 |
889
Rep 2,556
Drives: Z4MC-X3-35i-525i, Corrado G60
Read the stored error code(s) or take it to a shop for diagnostics. You didn't mention the engine model, but the N20 is known to self destruct due to the failed timing chain system that starts with a whining sound
05-22-2022, 04:08 PM | #3 |
Rep 29
yes N20.. im aware of chain issues.. so far no problem... i was over powering my car in uphill -cruise control in 90+km ..
i guess the winning sound was imagination after the error code might be... today I ve checked no such sound. there is no fault code display in idrive but ... then run diagnostic obd2 Carista v6.5.1 Android app i got this... Junction box (passenger) (JBBF): 8020E9 8020D9 Engine: 120308 - Charge-air pressure control, lower value: charge-air pressure too low Traction/stability control: 4809AB - DSC: undervoltage in vehicle Center roof module: 801A4C 801A4A - Anti-theft alarm system: tilt sensor and interior movement detector deactivated Infotainment system: E1C440 - HU-H: reset Central module (in driver's footwell) (FRM): 800F92 - Welcome light, repeat interlock, active please explain is it major issues ... Last edited by apanner; 05-22-2022 at 04:43 PM.. |
05-22-2022, 08:05 PM | #4 |
889
Rep 2,556
Correlate the engine/traction errors with kilometers they happen to match your last trip with the failure. Clear all errors and check again after driving a while. Maybe it was a glitch
tracer bullet2515.50 |
05-23-2022, 10:24 AM | #7 |
Dr Drei
71
Rep 245
I'd check for boost leaks as well. It looks like the MAP sensor detected low charge pressure, which means boost is escaping somewhere.
The transfer case fault is interesting too. Are you original driveline fluids?
GLK 250 // 126xxx miles // 36 MPG // Mobil1 ESP 5w30
05-24-2022, 11:29 AM | #9 |
Rep 29
thanks for the info... Yesterday i was again drive through in mountain areas... no so such problem.. no notification.
I run test again Carista /Bimmerlink app... only one error code is showing #8020E9 i hope i ill get away with this... still i ill check for leaks ... thanks Last edited by apanner; 05-24-2022 at 06:45 PM.. |
