05-17-2022, 04:48 AM | #1 |
Rep 81
BM3 vs tuner
Hello,
I want to do a stage1 on my b48b20b (520i) but I'm not sure wether to go with bm3 or with a local tuner shop. The difference price wise is about 100$ as bm3 is 595$ and local tuners do it for 500$. I'm not trying to get squeeze every single hp I can get from the tune but to have a little more power. I've read I can get around 250hp without going crazy on the engine; the car has now 184 stock Any advice would be helpful. Your experience with bm3 over the local tuner (if you had both) Thanks! |
05-17-2022, 05:43 AM | #2 |
Rep 113
Good morning! I went with BM3 on my 530i I had previously. Was super easy. Just did a stage 1 OTS tune. It made a WORLD of difference. With that being said- your local tuner should be able to utilize all the same software to do a tune on the spot specific to your car.
Essentially- go BM3. Load an OTS. Then your local tuner can also log and tune utilizing the same program. There are also numerous tuners throughout the country that can remote tune you with the software. You log, send them the file after they have built you a base map. They then adjust parameters specifically to your car. I’m not certain there would be any dramatic difference over the OTS if you’re staying stage 1. So no downpipe. |
05-17-2022, 06:11 AM | #3 | |
Rep 81
Thanks for the reply! I don't (think I) need something specifically for my car. I just want a boost of power. Did you play with the exhaust settings (burbles and so) on the 530i? |
05-17-2022, 06:44 AM | #4 | |
Rep 113
Tell you what though, the BM3 OTS stage 1 gave me what felt like a 540 power. My little fake HP gauge was as pegged out above the meter. It was an Xdrive, was very fun. If I had kept it I would have done DP at least. |
05-24-2022, 08:03 AM | #5 |
Joint Chiefs of Staff
24388
Rep 191,223
Go with bootmod3; their maps are proven to work safely on thousands of cars.
They also offer free upgrades now and then, including new features, more power, and smoother delivery.
05-29-2022, 10:15 AM | #6 | |
Rep 81
Do you have a link from where I can purchase bm3? I hvave enet cable so that ain't needed. Cheers! |
05-29-2022, 10:30 AM | #7 | |
24388
Rep 191,223
06-01-2022, 01:33 PM | #8 |
Rep 59
I would recommend MG Flasher, I switched over from BM3 and MGF is a great tune, I'm currently stage 1 and soon to be on stage 2. Don't get me wrong, BM3 is an ok tune but their customer support after purchase has a lot to be desired. I had a BM3 tune on my previous 550i and they left me hanging on an issue I had, so they lost me as a customer.
2018 G30 530e M Sport - MGF Stage 2, Catless DP, 6WB retrofit
2018 Audi FM Q7 - APR Stage 2 SP, BMC/Roc Euro Intake 2014 F10 550i M Sport 2008 E60 M5 2005 E46 M3 |
06-03-2022, 02:32 AM | #9 | |
Rep 81
I need to search more about MG Flasher as it's quite new to me. Do I need to consider something else before going stage 1? Like changing spark plugs or ignition coils? I need to do the oil change (filters and so) in about 3k at the delear and if the car is there for the maintenance I can ask them to take care of the others if it's needed. After the visit at the delear I will go stage 1. Thank you for sharing your experience. |
06-10-2022, 12:31 PM | #10 | |
Rep 59
It looks like you have a 2018 so let's assume you have about 40-50K miles on your car. If you are going to tune I would recommend changing your plugs, filters and oil to start fresh, just as you noted. If the coils look great I'd leave them for now but once you're tuned you'll probably want to change them after 10-20K miles or so after tune, depending on how aggressive you go. This will put you on right on schedule to change them out anyways (50-65K miles max is recommended to change coils on a stock BMW). This is what I did for my current 2018 530e. Right before I flashed I changed the filters, oil and plugs but left my coils for now, they look in good shape, and I will probably change them after another 10K miles. So far no knocking, misfires and all is good.
06-11-2022, 04:50 AM | #11 |
Rep 803
Honestly, if you're only looking for a little boost, have you considered piggy back units? The JB+ will give you a nice bump and all you have to do is plug it in.
Tuning would be more precise, but its plug and play and you can find them for less than $200. |
06-16-2022, 03:50 AM | #12 | ||
Rep 81
Moneywise, I would rather spend extra 200$ and get it done by the book. Quote:
NGT25719.50 |
06-21-2022, 03:41 PM | #14 |
Rep 59
I would agree, I went from stage 1 and currently on stage 2, I did notice a little bump but nothing significant from s1 to s2. I added a catless downpipe and love the sound. Currently getting about 20/21 PSI max, I wonder how much the B46/48 can handle? Only way I can squeeze a little more is through stacking a piggy back like the JB+ on top of the stage 2 tune.
Tags |
b48, bm3, tuning |
