05-13-2022, 10:14 PM | #1 |
6918
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
50th Anniversary Badges
Dealer just notified me that my individual order from Dec is finally going into production in June. I inquired about the 50th Anniversary Badges and they told me that in Canada it's a $300 option. Anyone else have any info on this?
05-13-2022, 10:32 PM | #2 |
13475
Rep 6,962
Drives: 2022 DG/BLk xDrive M4C Wk 34
Not according to your ordering site. Make sure you make changes to your order before 150 status.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
05-13-2022, 10:38 PM | #3 |
6918
Rep 3,277
That's what I thought. Thanks!
Limegrntaln13475.00 |
05-14-2022, 05:53 PM | #4 |
Rep 754
Drives: 09 //M3 e90 Interlagos Blue
In general, the 50th Anniversary Classic M emblems became available after March 2022 on ///M cars and ///M Performance car. They were added by default, unless you declined. Not sure if that means orders placed after March 2022 or production starting after March 2022.
Check with your BMW dealer...based on your build sheet. Either way, if your baby arrives without them, the dealer will make it right, since they should have a bucket load of these 50th Anniversary Emblems which are in high demand. You can go on the BMW Configurator and see if they they look good with your exteriors paint and wheel finish. You might have to mix and match. There are also floating wheel center cap options to retrofit. Cheers |
Forzanerazzurri6918.00 |
05-14-2022, 08:47 PM | #5 | |
6918
Rep 3,277
05-14-2022, 11:49 PM | #6 | |
Rep 243
F90
05-15-2022, 02:30 AM | #7 |
13475
Rep 6,962
Not all countries are the same. In Canada, you have to select it for the build, yourself. The US cars, you have to check the box to remove them, because they are standard. If you haven't entered into 150 status, you should be able to modify your order. Read post #2, above, in Canada you have to select it, yourself.
YT: G Dubyou |
05-15-2022, 08:43 AM | #8 | ||
Rep 133
Drives: 2022 G82X individual
05-15-2022, 10:33 AM | #9 |
Rep 754
Rush111 - Check out the Rush Moving Pictures 40th Anniversary Super Deluxe Album for $300 -- weigh 20 lbs with drumsticks, books, Vinyl, and a Red Barchetta. Ridiculousness.
You can always add the 50th Anniversary Roundels or your dealer can swap them out. Available to order the parts in June 2022. Cheers Last edited by nyc_dude; 05-15-2022 at 10:47 AM.. |
05-17-2022, 08:01 PM | #11 |
6918
Rep 3,277
Just went to status 112 (individual order) and they say it's locked in so I'll have to get the badges after. No big deal.
05-17-2022, 09:41 PM | #12 | |
Rep 253
Drives: BMW M3 Comp Xdrive
Just received mines today |
05-17-2022, 10:11 PM | #13 | |
6918
Rep 3,277
05-19-2022, 10:15 PM | #14 |
6918
Rep 3,277
Does anyone know if the front and rear roundels on the g80 m3 includes adhesive on the back or is it just like most models where it just pops off the grommets?
05-20-2022, 05:07 PM | #15 | |
Rep 754
Would you post the P/N photo on the box? You can see that the rear roundel has a hole at the bottom for a rear sensor. Most folks won't want to order that version. IND has the 50th Anniversary wheel center caps, but wait a few weeks to get a better price. They are probably only for certain models like the G8X M3/M4. There are 3 or more sizes for different model platforms. Cheers |
05-20-2022, 07:47 PM | #16 | ||
Rep 253
These P/N are for the M4 G82 front: 51 11 7 886 545 Rear: 51 14 8 087 199 Tire Center: 36 12 5 A57 484 Just install today |
05-20-2022, 08:03 PM | #17 |
6918
Rep 3,277
Did the old ones pop off or were there adhesives on the back
05-20-2022, 09:00 PM | #18 | |
Rep 253
Once it separated, used trim tool to pop them right off. Cleaned off residue and pushed new ones on. |
05-20-2022, 09:16 PM | #19 |
6918
Rep 3,277
05-21-2022, 01:50 PM | #20 |
Rep 754
Well done. Looks fantastic.
For others... - Pick up a replacement set of grommets for older cars. - Many BMW Roundels use an adhesive now, so the removal might require a heat gun/blow dryer. $%#%^$# BMW - The front hood emblem P/N should be universal (82mm). - The rear trunk emblem P/N will change depending on model and options (74mm). Some SAV rears are the same size as the hood roundel. - The wheel center caps are different sizes for different models. - The wheel center caps should come in a non-floating standard and floating versions. If you have to spend extra money, might as well go floating center caps. Hopefully, they will hit the US market after next week in June, after the Memorial Day Holiday weekend. Cheers Last edited by nyc_dude; 05-21-2022 at 02:58 PM.. |
05-21-2022, 02:06 PM | #21 |
Rep 285
Drives: 2021 M340 RWD
I just ordered
The hood and trunk ones from BMW Parts Pros. I have a mineral white metallic M340. From the pics I have seen these look fantastic.
"Either get busy living, or get busy dying. That's GD right." - Red (Shawshank)
05-21-2022, 02:42 PM | #22 |
Rep 754
BMW 50th Anniversary Classic M Roundel P/N Decoder Ring Table.
https://paddleshifterz.com/product/b...v=7516fd43adaa The BMW 50th Anniversary Classic M wheel center caps are probably only available for G8x M3/M4 wheels and other similar models with a single p/n for the non-floating set. There are different p/n's for older F/E model BMWs. A separate set of p/ns for floating center caps for different wheel hub diameters. Cheers |
