04-19-2022, 03:07 PM | #1 |
Rep 27
Litchfield Bilstein EDC coilover kit on order
I'm about to order the Litchfield kit for my CS. See Chris Harris' vid on it if interested.
The kit is about $4300 shipped. If anyone else is interested, we might be able to get a discount.... https://www.litchfieldmotors.com/bmw...ling-upgrades/ Litchfield and others say the ride quality is softer then stock in "comfort" mode and maybe a tad stiffer in "sport +". Most owners of Litchfield suspension seem to be very happy with the setups (shock compression/rebound settings and spring rates). Litchfield also sends a recommended alignment setup based on your driving goals. |
04-19-2022, 03:37 PM | #2 |
2185
Rep 2,364
Did you contact them directly? If this kit could be set very near stock ride height, or perhaps only 1/8" lower max, I could be interested. Slightly softer ride in comfort might be worth it, especially if it can be stiffened up with the other two settings.
BSM ///M2cs, 6spd
04-19-2022, 04:04 PM | #3 |
Present:
111
Rep 33
Watched the video numerous times and have thought about it. Looking forward to your feedback after install and drive
04-19-2022, 04:10 PM | #4 |
Rep 27
I have talked with them directly. I didn't ask that question but just emailed them. Good question. I don't really care as my 1st priority was lowering the car but this will be good to know. Their next shipment of kits is about 2-3 weeks away and they ship Fedex or UPS to the states. Shipping is roughly $375.
04-19-2022, 06:46 PM | #5 | |
2185
Rep 2,364
BSM ///M2cs, 6spd
04-19-2022, 07:28 PM | #6 |
Rep 155
The engineer in me has a lot of questions about this. Experience has demonstrated that small changes to valving can make huge benefits so I suspect they have created something that is really neat, but my money, at least for now is going into camber plates and control arms.
Please do keep us updated on the outcome! |
04-20-2022, 05:47 AM | #8 |
2185
Rep 2,364
While I agree with this 100%, I am fairly certain the opportunity will not present itself. It would be nice for another CS owner to review these and say with absolute certainty that the ride quality is improved (in comfort). I am not looking to make this car handle better, in stock for it is way more than I need on the street.
BSM ///M2cs, 6spd
g.lor108.00 |
04-20-2022, 10:25 AM | #9 | |
3034
Rep 13,777
~loud noises~
M3R12185.00 |
04-21-2022, 07:23 PM | #10 | |
Rep 155
I ended up going down the SPL rabbit hole and purchased their front tension rods, front end links and lower control arms, rear tow links, rear upper and lower arms and traction links. Also ground control front camber plates. The above *should* based on past experience result in a more or less stock car with the ability to vastly improve the alignment front and rear and most importantly have it stay at said adjustment on the track. Time will tell I suppose and maybe I am wrong. Such is the process. |
sdhotwn2128.50 |
04-22-2022, 12:55 AM | #11 |
Rep 139
I have these on order since January. Originally, they said it would be ready to ship by late / Feb / early March, however as of last update two weeks ago they said Bilstein had a delay in machining some of the parts and still waiting for an ETA unfortunately.
I decided to go with this set as I have had positive experience with the Litchfield Bilstein set for the R35 GTR before. The CS stock suspension setup feels a bit skittish / too harsh on my local roads. I wanted a suspension that would retain the EDC capability (daily driver) while offering a more supple ride, which I have found with the GTR setup before. Time will tell if it works as prescribed. Will post some notes when it arrives (eventually). |
04-22-2022, 09:13 AM | #12 |
1254
Rep 4,088
Are the folks here who have ordered this kit planning on using them with factory top mounts or in conjunction with camber plates?
This kit is on my list of very likely future mods. |
2020M2Competition429.00 |
04-22-2022, 11:51 PM | #13 |
6574
Rep 3,089
Drives: M2 CS, 18 Vantage AMR, 00 WRX
Are you using comfort mode? Have you gone to "lowering springs"? I've got a bumpy fast bit of road where I am and I'm amazed how good it is. No sign of being skittish at all. That was the biggest difference for me between M2C and CS. The C definitely became skittish. The CS is firm but compliant in comfort. Comfort is of course a complete misnomer. It should be called bumpy, normal, smooth performance mode. Luxury comfort ride is not in the vocabulary of this car and nor would I ever want it to be.
04-23-2022, 04:04 AM | #14 |
Rep 142
M2 Cs Suspension : Comfort Mode is Very Poised
Interesting that someone states that they find the Cs suspension is very “skittish” in Comfort Mode .
I find that very surprising and not what I have experienced. My Cs is just as it was manufactured and with nil modifications to the suspension . Where I live (Perth Wa) the roads can be far from perfect and in Comfort Mode it is very Compliant and Poised . I was genuinely surprised just how good the Bmw M EDC Suspension Engineering is . My Cs is fitted with the Michelin Sport Cup 2 tyres which complement the suspension for grip and stability. Cheers Bruce |
04-23-2022, 04:09 AM | #15 | |
Rep 139
Hi Davil, the car is surely left in comfort mode and on stock setup. In fact, it has become 2nd nature to switch to comfort damping / steering / and econo engine setting as soon as I roll out from my garage spot before switching to engine in sport later after oil temp is at normal operating level. I would not even bother with switching the damping away from comfort and is left there for 99% of time I use the car.
The roads in my area are hilly, twisty, and not the smoothest tarmac by any means so from years of experience of driving various cars there I have sort of developed a gauge of road feel, although from a very personal enthusiastic driver view and not a scientific one whatsoever. I only wish I have studied such a subject to offer more objective input in that regard! With the CS, driving through this road and amongst many in HKG with similar road surfaces, the interior would be rattling (i.e. passenger sun visor and some console bits creating creaks and other rattling nuisance. I have to admit I have a bit of OCD with excess rattling / creaking so it was a bit hard to accept.) Understand it's not a luxury limousine with magic carpet ride quality, but I have driven various sports cars of German / British / Italian make and it would not creak or rattle to this extent yet offered a supple, appropriately dampered ride quality). In comfort damping mode, those nuisances persist albeit to a lesser extent. I relate this to my experience with the Nismo R35 which was known to have high NVH. I daily driven that car and did not track it so swapped the OEM Bilstein to a custom valved kit that was still EDC compatible. It worked wonders on the the ride quality without compromise so I am simply looking that it will replicate the same experience with the CS. If it does not work as prescribe I can always switch back. I can see how you may allude that I have lowering springs as that sort of ride harshness reminds me of a time almost a decade ago when I just swapped out the OEM springs to H&R lowering springs in the Megane RS (MKII). Initially, it felt more 'sporty' with less weight transfer on spirited drives and seemingly improved traction. However, as soon as I travelled through certain local road sections where the pavement was less than glass smooth (not much of that nice stuff here really except on the highways) the sense of harshness and vibration would transfer through the chassis into my seats / steering, etc and the traction became somewhat skittish as the car 'bounced' around a bit more. It got worse as I daily drove the car so I imagine the struts were taking a lot more stress with the shortened travel and lowered working life. So I vowed never to put just lowering springs again. Just my 2 cents worth. Cheers. Quote:
04-23-2022, 07:58 AM | #16 | |
2185
Rep 2,364
I love the car like crazy as it is, but imagine if it was even better!!!
BSM ///M2cs, 6spd
04-23-2022, 11:00 AM | #18 | |
2185
Rep 2,364
Also please let me know if the ride height can be kept close to stock. Thanks!
BSM ///M2cs, 6spd
04-23-2022, 11:40 AM | #19 | |
Rep 139
Unfortunately there are some material parts delay according to Litchfield on Bilstein's side. It simply can't get here soon enough. |
04-23-2022, 01:23 PM | #20 | |
2185
Rep 2,364
Thanks again..
BSM ///M2cs, 6spd
krm347.00 |
04-27-2022, 01:11 AM | #21 | |
Rep 1,125
04-27-2022, 07:04 AM | #22 | |
6574
Rep 3,089
Other things. If 2nd hand, has it had any damage? It should never feel skittish. If no damage, how is the alignment? If those are ok, have you checked the tyre pressures? Over inflated tyres can make a mess of things, especially with Cup 2 tyres. I run mine around 35. Hope some of this helps. P.S., totally agree on lowering springs. You only enjoy them twice. Once when you get them, then when you get rid of them. A bit like owning a boat. |
Jimjamz4599.50 |
