bimmerpost/
BMW M2 and 2-Series Coupe
BMW 2 Series Technical Topics (G42) App, Nav, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      04-02-2022, 04:05 PM   #1
yanks1
Drives: '08 Mustang GT Vert 5-speed
need help: Compass?
Only thing i can find is the little arrow used for navigation. But doesn't tell you which direction you are driving. Is there a way to activate a real compass?? my 2018 230i had Compass in Rear view mirror I think
I am perplexed.. thanks
M240ix; Blue w/Black & Blue Stitching, M Illum. & Alum trim, Premium, M797 Bi-Color, Shadowline & HK Audio
'08 Mustang GT Vert w/5 speed manual
Past:325ci, 330ci (my favorite) & 2018 230i; '79 Vette (owned 13 yrs.)
      04-02-2022, 04:54 PM   #2
jpcoop
364
Drives: 2022 M240i xDrive
Yeah it seems like they took it out of the mirror. Bit of a bummer. You can add a compass to the iDrive home screen though I think. As one of the tiles.
TJZ67201842.50
      04-02-2022, 05:21 PM   #3
xcelir8bmw
xcelir8bmw's Avatar
Drives: 2022 BMW M240ix
I was annoyed at this as well and end up using the split screen for compass when I require it.
      04-02-2022, 05:42 PM   #4
yanks1
Which split screen shows the compass; I checked all settings & manual and no mention how to add the compass
      04-02-2022, 08:28 PM   #5
The Ching
The Ching's Avatar
Drives: 2022 G80 6MT
Use the Route Preview, it'll show a compass unless you have the navigation currently in use.
jpcoop364.00
      04-11-2022, 12:48 PM   #6
danallxt
danallxt's Avatar
Drives: 2022 M240x, 2007 Honda VFR
Note: the Navigation screen does have a compass orientation, I have mine set so North is always up....therefore any glance at the progress arrow tells me what direction i am going. In addition i have 2 other compasses in my 2022 240x, one i activate thu the turn signal stalk buttons, the other is on the split screen as has been mentioned, so in effect i have access to 3 different means to check my direction of travel. Seems like plenty?
      04-11-2022, 01:43 PM   #7
ZacMatic
Drives: 2022 BMW M240i xDrive
When you have the map open in the infotainment screen, push the controller to the right to access the menu on the right. At the bottom of the menu is a function labeled Split-Screen that allows you to display a widget side-by-side with the map. There's also a settings option that you can use to configure what goes in the split-screen, such as compass, trip overview, traffic alerts, etc.
      04-18-2022, 05:09 PM   #8
steelatx
Drives: BMW M240i
Turn signal stalk button shows compass? Does the BC cycle has a compass vieew or is this something else you're referencing?
      04-18-2022, 06:40 PM   #9
Hpirx
Drives: 2022 M240 xDrive, BGM
On the Home Screen, swipe left on the touchscreen, a compass is hiding 2 or three tiles over.
Retired: '08 335xi E90. "Long may you run."
Retired: '19 M240xi "You also"
g87
