03-30-2022, 09:01 PM | #1 |
Rep 934
Stepping into another E90 soon. This will have to go eventually, so figured I'd list it now. Or I'll just keep it and turn it into more of a track car. Currently sits at ~160,000 miles. This is my 3rd E46 M3, and this one by far is the most mechanically sorted. No weird noises. No fluctuations in idle. Just turn the key, and go. Not the prettiest car, but I enjoy that about it. Don't have to worry about rock chips while chasing down GT3s in the canyons. Almost every aspect of this car has been refreshed to like new, or better. I just took a 1,400 mile road trip in the car and didn't think twice about doing so. Car currently has a radio delete panel installed, although I do have a car-play nav unit ready to be installed if that's your thing (comes pre-wired). Mods: TMS 80A FCABs TMS 80A transmission mounts TMS solid subframe bushings TMS spherical RTABs (in-box) TMS camber arms (in-box) Refreshed shifter bushings OE M-Performance shift leaver BC DS coil-overs Enkei 18x10et25 squared RE71R 275/35 squared (brand new) TMS 80mm wheel studs Subframe reinforced (plates above & below) Gussets welded in trunk; subframe support Radium surge tank Radium oil catch can Koyo radiator StopTech SS brake lines StopTech rotors StopTech street pads OMP steering wheel hub Momo Monte-Carlo 350mm steering wheel Maintenance: Rod Bearings VANOS overhaul + high pressure VANOS line Water pump, radiator hoses, t-stat Timing chain kit Coil packs Injectors Valve cover walnut blasted Rear main seal Clutch (upgraded) & flywheel Rear wheel bearings Guibo/Flex/Disc Engine mounts OE (new) parts, recently replaced: OE alcantara shift boot OE ZHP shift knob Euro Center Console (arm rest delete) Euro Center Console trey Radio delete panel Single din lower valence OE chrome front grilles OE chrome side grilles OEM clear side markers OEM clear corner lights OE floor mats I welcome PPIs/inspections and test drives (for serious buyers). The underside of this car is immaculate. Most bolts still have their original zinc coating. Last edited by 911r; 03-30-2022 at 09:17 PM.. |
04-02-2022, 09:23 PM | #3 |
Rep 934
