BMW 5-Series (G30) Forum Mechanical Maintenance - Break-in, Oil, Fluids, Servicing If I use BMW LL-01 oil instead of BMW LL-14 FE+ will I be voiding warranty?
      03-26-2022, 09:18 PM   #1
Mosaud1998
Mosaud1998's Avatar
Drives: 2019 BMW 540
2019 BMW 540  [0.00]
I did oil changes on my E90 myself. I used LM 5w-40. So, I am planning on changing the oil on the G30 every 6 months of 5k miles.
I know BMW recommends LL-14 FE+ rated oil for better fuel economy on the newer BMWs. Can I run LM 5w-40 in the G30 or would that be too thick? I'm not going to be tracking it. Just driving to and from work.
Would running LL-01 void the 2 years of warranty I've got left?
0w-20 seems to thin to be running in a BMW IMO
      03-26-2022, 10:48 PM   #2
ezaircon4jc
ezaircon4jc's Avatar
Drives: 2019 540i M Sport
I don't know how BMW's valvetronic works, but VVT usually is controlled by oil pressure. A thicker oil can mess with that system. I would stick with the oil that the engineers designed the system to run.
Mosaud19983940.50
2022M550i3034.00
      03-27-2022, 03:07 PM   #3
430Scud
430Scud's Avatar
253
Drives: M550iX,430 Scud,E39 540Msport
Which engine do you have? For the N63 the approved oils are LL-01 FE and LL-17 FE. I just had my last free oil service on Friday and asked they only use the 0w-30 LL-01 FE...and not the thinner crap, even though it is "approved". I intend to use LL-01 on the next change, since I will be out of warranty.
The simple fact of the matter, is these FE (fuel economy) oils have lower High Temperature High Shear (HTHS) ratings than LL-01. Higher HTHS will protect rod bearings, and turbos better than a lower HTHS. Yes, and it will slightly impact your fuel mileage as well. I'm willing to sacrifice that.
OP, maybe the compromise oil to use is LL-01 FE 0w-30 oil??
Mosaud19983940.50
      03-27-2022, 03:12 PM   #4
430Scud
430Scud's Avatar
253
The vanos system has been around for like 30 years, and used on BMW engines requiring anything from 0w-20 to 10w-60. Whether is has been recently optimized to only work properly with a 0w-x oil is for sure something to consider. I am doubtful it matters. But each owner needs to make their own decision on the matter.
      03-27-2022, 03:39 PM   #5
2022M550i
2022M550i's Avatar
3034
Drives: 2022 M550i, 2015 Viper
I would recommend keeping a log and receipts of your "do it yourself" oil changes. If you have an engine failure that requires warranty work, that log and receipts will be your best friend.
Mosaud19983940.50
430Scud253.00
      03-27-2022, 03:42 PM   #6
Mosaud1998
Mosaud1998's Avatar
2019 BMW 540  [0.00]
I was thinking about using this oil
https://www.fcpeuro.com/products/bmw...11428583898-lm
Current: 2019 BMW 540 (AWD)
Sold: 2009 BMW 328 (AWD)
      03-28-2022, 10:56 PM   #7
430Scud
430Scud's Avatar
253
No, that is mismarked as LL-01. It is not. It is LL-17 FE+ (look at the close up of the bottles in the FCP Euro page)
To prove it, go to the Liqui Moly website and look at the "Specifications and approvals" drop down page
https://products.liqui-moly.com/top-...-0w-20-12.html
All BMW LL-01 approved oils will only be found in 5w-30 or 5w-40 viscosity ranges. There are no 0w-X BMW approved LL-01 oils.
I have no idea if it hurts your warranty or not, but the compromise would be to use an LL-01 FE oil like the BMW 0w-30, if you don't want to use an LL-01.
Mosaud19983940.50
      03-29-2022, 07:45 AM   #8
Mosaud1998
Mosaud1998's Avatar
2019 BMW 540  [0.00]
To prove it, got to the Liqui Moly website and look at the "Specifications and approvals" drop down page
https://products.liqui-moly.com/top-tec-6600-0w-20-12.html" rel="" target="_blank">http://<a href="https://products.liq...20-12.html</a>
Damn, I didn't even notice that. I think I'll use BMW 0w-30 while I'm in warranty and then switch over to 5w-30 once the warranty expires.
430Scud253.00
G30 B581548.00
      04-18-2022, 07:37 AM   #9
Joe-BMW33
Joe-BMW33's Avatar
7338
Drives: '18 M550i|'21 X5|'03 540i
2013 VW Tiguan  [0.00]
2015 Infiniti QX60  [0.00]
2021 BMW X5  [0.00]
2003 BMW 540i  [0.00]
2018 BMW M550  [10.00]
For what it is worth, I let my independent shop do my oil changes. I trust them more and it's more convenient. I document everything. He recommended LIQUIMOLY SAE 5W40 LEICHTLAUF HIGH TECH LL01 and a Liquimoly CeraTec flush. I'll tell you, I have not had one issue with consumption with the LL01 5W40. I used to have to add a quart or two every now and then with the 0W stuff.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi|
Appreciate 3
Mosaud19983940.50
430Scud253.00
      04-18-2022, 11:01 PM   #10
430Scud
430Scud's Avatar
253
Again, it is not just the viscosity range of the oil, it is the approval ratings that equally matter. Not all 5w-30 oils have an LL-01 rating. Make sure what you use is LL-01 rated, it ensures a very robust oil, compared to non LL-01 5w-30 oils.
Mosaud19983940.50
      06-18-2022, 11:24 AM   #11
cbarlow
Drives: 2013 335ix, 2019 540i
For what it is worth, FCP Euro has an article recommending against the use of 0W-20 LL14FE+:
https://help.fcpeuro.com/hc/en-us/ar...like-BMW-does-
I'm running Liqui Moly 5W40 Leichtlauf High Tech in my 2013 335i and am thinking about using the same in my 2019 540i. Stocking a single oil for both vehicles is appealing. The alternative under consideration for the 540i is Liqui Moly 5W30 Special Tec LL.
Mosaud19983940.50
Joe-BMW337337.50
      06-18-2022, 02:59 PM   #12
Mosaud1998
Mosaud1998's Avatar
2019 BMW 540  [0.00]
I think I am going to go with either 5W-30 or 5W-40. Idk yet tho
Joe-BMW337337.50
      06-18-2022, 05:16 PM   #13
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Had a long talk with my tech, he swears by 40.
Mosaud19983940.50
      06-18-2022, 05:21 PM   #14
Mosaud1998
Mosaud1998's Avatar
2019 BMW 540  [0.00]
My indy said they use 5W-30 LM in non-tuned B58s and 5W-40 in tuned B58s. I ran 5W-40 in my E90 with the N52
      06-18-2022, 06:38 PM   #15
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
I've got the N63TU2 and 5w-40 is an approved oil. All I know is there is ZERO consumption. I'm not an oil expert, I was using 0W-30 before the last two changes with 5w-40 and I'd have to add 2-3 quarts between changes. Something tells me that can't be good, using an oil that burns up and gets consumed.
Mosaud19983940.50
      06-18-2022, 07:30 PM   #16
Mosaud1998
Mosaud1998's Avatar
2019 BMW 540  [0.00]
I'm not having any consumption issues right now. But, I used 5W-40 in the E90 because of consumption issues and lifter ticking
      06-21-2022, 10:00 PM   #17
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
I wish it wasn't so hard to look at the intake valves on these engines. I'd love to see your valves with that kind of oil consumption. Not saying it all went into the PCV system, but some of it did...
FWIW, I have zero oil burning with the stock oil. I'm going to be doing my first out of dealer service oil change on the M550i in August. I'll be using LL01 oil. Maybe Amsoil. Maybe something else. My buddy with the shop I do work at uses Liquid Moly so he has that in stock. I like to buy my parts and stuff from him since he lets me work on my cars for free...
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
      06-22-2022, 02:04 AM   #18
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Yeah, I'm no expert so not quite sure what your trying to discover, but oil consumption in these engines is not abnormal and a decent amount of people experience it, so I wasn't alone. The few quarts I had to add were during the interval between taking delivery and 6-8k miles. Then I went with 5w-40 and no consumption. So it's the oil, not the engine in my unqualified opinion.
      06-22-2022, 04:37 PM   #19
admranger
Retired Curmudgeon
admranger's Avatar
I'm wondering if your car has this:
      06-22-2022, 05:32 PM   #20
ezaircon4jc
That looks like it's from an N54!
      06-22-2022, 07:51 PM   #21
admranger
Retired Curmudgeon
admranger's Avatar
2.0 VW actually. Just a random googled pic of what I was wondering about.
      06-23-2022, 02:29 AM   #22
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Yeah, pretty random.
5post
