03-21-2022, 11:43 AM | #1 |
9588
Rep 10,878
IND | Eventuri G8X M3 / M4 Carbon Intake System
Performance Gain: 13-18hp, 12-16ft-lb (Stock Tune) Turbo Inlet Area Increased up to 160% Filtration Area Increased up to 40% Presenting an intake which truly sets a benchmark for the BMW G8X M3/M4 platform. We have carried out intensive R&D to develop an intake which not only improves on the stock M3/M4 but also is future proof in its capacity to cater for high powered builds well in excess of 1000hp. Our system is a complete redesign from the airboxes to the turbo inlets with the aim of reducing pressure loss while increasing the flow rate and keeping inlet temperatures low. We have maximized the usage of the available space to employ 2 custom made filters with a 40% larger filtration area than stock. These are used in our Patented Venturi housings to smoothly funnel the air to the turbo inlets. The inlets themselves are up to 160% larger in cross sectional area than stock and are designed with an advanced dimpled inner surface to reduce frictional losses between the flow and the wall boundary. By allowing a “cushion” of air at the wall surface, airflow is able to move through the inlets at higher flow rates with reduced pressure loss. This allows the turbos to draw air with less resistance and therefore reduce the wastegate duty cycle resulting in higher overall performance. Installation Guide The Eventuri G8X M3/M4 intake system consists of a number of components engineered to perform a specific purpose and fabricated to the highest of standards. We use 100% pre-preg carbon fiber with no fibreglass which means we can achieve a smooth internal surface to maintain smoother airflow. Each intake system consists of:
The Eventuri G8X M3 / M4 Carbon Intake System may be viewed at the following link to our online store: https://ind-distribution.com/product...-intake-system Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
03-28-2023, 07:37 PM | #3 |
Rep 6
Installed on G82 M4 6spd :)
DEFINITELY one of the sexiest cold air intakes on the market for ANY vehicle!
It IS more expensive than most, however, you DO get what you pay for. The engineering ALONE that went into designing this bespoke CAI for the G8x M series is remarkable! The installation IS challenging, but doable with the proper tools and experience. I recommend either doing the installation yourself (if you're a pro), watching a pro do it, or assisting the professional so that you know what goes into it and how to disassemble it when it comes time to clean the filters. MANY thanks to the engineers, fabricators, techs, and entire team at Eventuri for this incredible CAI system! Last edited by M4T8; 03-28-2023 at 07:47 PM.. Reason: Adding images |
IND-Distribution9587.50 |
