      03-17-2022, 03:04 PM   #1
libbyren
Drives: 01 E46 m3 munual
Socal/LA 01 M3 manual for sale
USD 15,000.00
6 speed manual with UUC EVO3 short shifter with DSSR.
Rod Bearing replacement done.
Rear subframe reinforcement done.
Factory options includes xenon headlights, power-adjustable front seats, a Harman Kardon sound system and 6-disc.
The engine is found as a post-2003/04 model (oil pan and crankshaft is different) when doing the rod bearing replacement, which means the engine has LESS miles than the odemeter.
4 key fobs with 2 remotes, one valet and one plastic.
Very well maintained.
3 sets of wheels with tires and extra one set of wheels. One BimmerWorld forged wheel with PS4S, one 19" style 67 OEM (also forged) with Bridgestone Potenza S-04, one 18" Style 67 OEM with Goodyear in the storage. Extra one set 18" Style 67 OEM squared.
Never tracked in my hand.
Flaws:
Rock chips on driver's door and rear fender flares
Scratch on front bumper and crack under the front bumper
Rear view mirror has scratches inside the mirror
Broken speaker cover on driver's door
Right seat occupancy sensor sometimes not working well when someone is sitting.
Power Steering liquid leak, but have parts purchased to give.
Quarter Weatherstrip failed
Mod:
SPAL electric Engine Cooling Fan with clutch fan removed.
E46 m3 KONI yellow set (Adjustable Compression) with eibach Pro-Kit Spring set.
BimmerWorld forged wheels (square set) with PS4S
Stainless Steel Brake Line-E46,very solid and tough (condorspeedshop)
Orginal headers, OEM Exhaust section 1 with small resonator changed to straight, Meisterschaft Stainless Steel Section 2 and Eisenmann Sport Exhaust with LeMans 83mm Tips. (have all stock parts from section 1 to muffler in the storage)
OEM strut bar (not come with factory in a 01 model year m3)
Powerflex front and rear sway bar bushing
Left headlight ballast was replaced with Morimoto one and no error code on dash.
3 dot LED lights connected to fog light wired on bumper.
Eonon Car Stereo with Apple Carplay
Black suede steering wheel cover
LED interior lights
Rear Wheel Spacee 12.5mm
Eagle eyes LED tail lights (stock ones kept )
Service History:
Rod bearing replacement.
Front lower A Control Arm with new Arm Bushing replacement.
New suspension as stated in Mod
Front sway bar link replacement.
Front tie rods replacement.
Rear sway bar link replacement.
New Shock Mount with shock mount reinforcement
Front and rear sway bar bushing replaced as stated in Mod.
Alternator replacement.
Air filter replacement
Cabin air filter replacement
Driver side weatherstrip replacement.
New brake pad and disc for both front and rear.
New Genuine BMW Ashtray With Roller (Black-Chrom)
New coin tray.
Brake caliper replaced with Centric renewed E46 m3 caliper.
New brake lines for front and rear as stated in Mod.
Fairly new tires PS4S (Less 2000 miles).
Transmission oil refreshed with .
Engine oil refreshed with LM 10w60 and MoS2.
Rear diff oil refreshed with Motul 75W140 Competition Gear Oil.
Brake oil refreshed with ATE DOT 4 SL.6 Brake Fluid.
Coil pack replaced.
New Bulbs for both right and left
New Trunk lid lift support
New exhaust seal ring and flange gasket with all new bolts and nuts
New battary.
Water pump was replaced by previous owner.
Parts to give:
6 new spark plugs.
One Exhaust Hanger
Power Steering Reservoir
Power Steering Return Hose
Power Steering Suction Hose
Fuel Filter
New Valve Shim Service Kit
Thermostat
Fan Clutch (You don't need it since I convert to electric fan)
      03-20-2022, 04:49 PM   #2
JimZm
Drives: Adidas
What do you mean by parts to give?
      03-21-2022, 03:03 AM   #3
libbyren
Those parts will be with the car for free
      03-29-2022, 10:42 AM   #4
Jabbadabop
Drives: 2003 BMW M3
Texted you again
      04-05-2022, 02:31 AM   #5
libbyren
bump, still available
      06-23-2022, 03:09 PM   #6
dlee825
Drives: 2009 E90 M3
Is this still available?
      02-05-2024, 09:39 AM   #7
libbyren
Bump, still available, now the price has been cut to $15,000. Since it's a little over 200,000 miles now. And had vanos rebuilt done by Baisan systems in 2023.
      02-06-2024, 05:35 PM   #8
911r
911r's Avatar
891
Drives: slowly
I’m interested in purchasing the BimmerWorld wheels if someone would want to purchase the car on squared style 67s for an (even) cheaper price
      02-07-2024, 04:57 PM   #9
jfivesix
Drives: '14 335i EWG
Is the vehicle still for sale?
      02-26-2024, 05:58 PM   #10
BlackFlagNik
Drives: M3
intersted in e46 m3
Check PM.
