02-15-2022, 09:12 AM | #1 |
Rep 223
CEL 18901 Lambda probe before cat
hey guys,
Just noticed this code today. Lambda probe before catalytic converter, dynamic: slow reaction I cleared the code in bm3, but i believe this is the o2 sensor before the cat, and i'll assume the code will probably come back. I still have warranty with bmw. if the code comes back, not quite sure how to handle. flash back to stock and lock the dme, bring it into the dealer etc. I realize that the dealers can tell if the car's tuned. no point in hiding that. at the same time, I assume a bad o2 sensor cant' be blamed on having a tune, but really not sure. or do i just go to an independent and have it addressed there. any advice would be appreciated |
02-15-2022, 12:54 PM | #2 |
365
Rep 529
Drives: 2019 440i XDrive GC
Be careful about bringing the car to the dealer. Your DME will likely be updated and relocked and will not be able to be flash tuned again.
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
02-15-2022, 07:16 PM | #3 | |
Rep 223
I did drive home pretty aggressively today and the code didnt come back on but I don't know if that means anything |
02-15-2022, 09:49 PM | #4 |
1665
Rep 4,910
If they think it's tuned, they won't warranty that. They can draw a nice clean line between more boost, more power, more heat = O2 failure. And you'll get the joy of a locked DME and non-tunable car.
It's an easy part to swap. I think you can do it without dropping the downpipe (don't quote me on that). It's a joke to replace when the downpipe is out though. |
02-15-2022, 10:15 PM | #5 | |
Rep 223
Was googling around on swapping the o2. Didnt find a straight how-to. But I believe the airbox has to come out and it's accessable from the top? |
02-20-2022, 05:35 PM | #6 | |
1665
Rep 4,910
Find a video on how to swap your downpipe, that will get you all the info you need for this. Quick question, are you getting a CEL, or just a silent code in the background. Sometimes glitches happen, and it will log a non-persistent code (IE not a full failure). |
02-20-2022, 10:40 PM | #7 | |
Rep 223
But I cleared it with bm3 app and it hasn't come back yet. |
02-21-2022, 12:39 AM | #8 |
Alexander Hartunian
60
Rep 95
Drives: 2018 BMW 440i
Please don't take it to the dealership… don't let them win.
2018 F32 440i - Black Sapphire Metallic - KW Suspensions V1 | VRP Intake | VRSF Catless Downpipe | Dorch Stage 2 HPFP | MHD OTS Stage 2 E40
Red-i80.00 |
03-29-2022, 03:34 PM | #9 |
221
Rep 445
03-29-2022, 06:16 PM | #10 |
Rep 1,449
Replace the pre-cat o2 sensor.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 |
jLona24029.50 e30 4 life!118.50 |
03-29-2022, 07:18 PM | #11 | |
221
Rep 445
03-29-2022, 08:25 PM | #12 |
Rep 223
It never came back. I had zero symptoms. I just happened to notice the cel on the dash.
03-29-2022, 08:51 PM | #13 | ||
Rep 1,449
05-05-2022, 09:34 AM | #15 | |
Melbourne Red F32 B58
59
Rep 99
I have had the P0420 code flash a few times and clear on its own. All stock no tune. I have since replaced my charge pipe and added the MHD MPPS tune. No CEL has appeared. I already made plans and purchased a HF DP and will most likely replace sensors just because. New car to me and having fresh parts will make me feel better.
Real drivers use 3 pedals. Its about connection.
05-05-2022, 10:26 AM | #16 |
Rep 72
Its a cheap and easy swap. Just purchase the lamda pre cat 02 sensor which you can purchase from trodo.com (i also replaced my post 02 sensor which i purchased off of ebay). I didn't have a code thrown but i was experiencing stuttering issues in every gear/driving mode which was due to a bad oxygen sensor. Once i swapped them out, car runs like a champ now.
05-05-2022, 04:50 PM | #17 | |
Rep 223
And would this be the right one https://partsavatar.ca/2016-2018-bmw...17404#OVERVIEW |
05-06-2022, 02:29 PM | #19 |
814
Rep 1,597
05-06-2022, 06:33 PM | #20 |
Rep 72
05-06-2022, 11:14 PM | #21 |
Rep 223
08-19-2023, 11:02 AM | #22 |
Rep 223
