01-11-2022, 01:38 PM | #1 |
9587
Rep 10,878
IND | Fall-Line Motorsports G8X M3 / M4 Rear Lower Control Arm Cup Subframe Bearings
MADE IN THE USA. From years of competitive race experience, Fall-Line has become synonymous with producing not only championship caliber race cars, but the finest suspension components that help propel them to victory. Rubber bushings found in the latest M Cars' rear camber arms are the last weak link in an otherwise rigid suspension. Fall-Line's new lower control arm subframe cup bearings yield a significant improvement over the factory bushings; as motorsport parts, both strength and longevity were priorities—to do just that, Fall-Line boasts the largest FK spherical bearings on the market—by eliminating rubber from a critical feedback area of the car, you gain control over the tire’s behavior and thereby confidence behind the wheel at the limit. To adequately cope with competition-level load, Fall-Line bearings feature stainless steel spiral locks that offer 360 degrees of clamping force to secure the bearing from any potential movement. As an added benefit, the spherical bearings will outlast the OEM rubber variants, saving the headache of repeated replacement over your ownership. As with any elimination of suspension bushings, more direct feedback can equate to a slight increase in noise, vibration, and harshness after installing these parts. Product Details:
The Fall-Line Motorsports G8X M3 / M4 Rear Lower Control Arm Cup Subframe Bearing Set may be viewed at the following link to our online store: https://ind-distribution.com/product...me-bearing-set Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
03-02-2023, 10:55 AM | #2 |
9587
Rep 10,878
Most Fall-Line Motorsports parts are in stock!
