      01-07-2022, 12:11 PM   #1
gorrerjm
Drives: E92 m3
2005 e46 m3 Competition Model
USD 34,000.00
2005 BMW M3 - Competition Model W/ 108K miles. Red on Black
We bought this to be a donor car, but its way too clean AND a comp model.
Car came to us a year ago with a failing SMG transmission. We swapped it to a 6 speed (w/a CAE shifter), replaced the Vanops, and fix some minor items, but left everything else stock. Serviced everything possible less than 600 miles ago. WE HAVE NOT DONE ROD BEARINGS but we can negotiate for us to do it before pick if desired.
Exterior: 9/10 Some small paint chips on the front bumper. Seats/Interior are an 8.5/10: Some wear on the interfaces in the center console.
Engine/Driveline: 8/10. Runs strong, all compression numbers above 172. Only reason an 8 is because we haven't dont the rod bearings. Trans went through and evenything is now 100%.
Will add more information at a later time! Car is currently with us, @ Quantum Speed Works - VIR
      01-07-2022, 05:52 PM   #2
kermmmit
Drives: BMW Z4 M
The best piece of ZCP packahe - wheels are missing. You should install them back .
      01-08-2022, 07:14 AM   #3
mdefalco25
mdefalco25's Avatar
Drives: 03 E46 M3
No interior pics?
      01-19-2022, 01:32 PM   #4
hutman
Drives: BMW M3
+1 Can you post some interior pics? What was done as far routine maintenance once you received the car?
News trans came off a donor car, I assume? How many miles on the transmission?
