12-05-2021, 09:45 PM | #1 |
109
Rep 462
Alternative solution to missing CS Armrest
Fellas
I figured out a great solution to what some call a deficiency in the armrest for the CS. It is incredibly easy to install although I will admit a bit costly. Step 1: order the akrapovic link pipes from IND. must be from IND bc they do an incredible job with the bubble wraps. Step 2: open trunk, lower rear seats, and insert link pipes with bubble wrap all the way up into the center console. Step 3: drive into the wind with your right arm so comfortably rested on this near tempurpedic bubble wrap. I will warn you, using the link pipe for an arm rest will not change the exhaust note one bit. I also found it to be an expensive solution to the missing armrest. It was very comfortable however. If you guys try it let me know what you think. |
