12-04-2021, 06:53 PM | #1 |
148
Rep 481
Drives: 2007 335 e90 1998 e39 540
Garage List 2023 BMW i4 m50 [0.00]
2020 BMW M340 [0.00] 2018 mx3 40 [0.00] 2016 340 [0.00] 2013 BMW ACYIVE HYB ... [0.00] 2010 BMW X535D [0.00] |
What are the benefits of a BMW Wallbox over the supplied NEMA 14 adapter?
I have an order for an I4 m50 and was wondering what the BMW wall box level 2 charger would offer me over the supplied accessories. I know I have to have a 220 line installed near the car. I don't think it will offer faster charging times. Anything other than programing charging times? Say at night?
I previously bought my daughter a VW ID.4. Charging infrastructure here in Long Island is terrible. There is only 1 DC fast charger that's not even near me. Any info greatly appreciated |
12-04-2021, 08:53 PM | #3 |
148
Rep 481
EA ia 25 30 minutes from my house. Not practical. No EVGO near by
12-04-2021, 11:08 PM | #4 | |
204
Rep 406
If you’re trying to take advantage of limited-time off-peak electric rates, then the higher amperage might provide a small benefit, depending on your daily mileage driven and the total time of off-peak rate availability. In my case, my car’s included charger, which supplies a maximum of 40 amps, easily recharges my car’s battery overnight regardless of how many miles I drive. The optional (extra cost) “wall box” type charger can supply 50 amps, but that wouldn’t make any difference at all to my daily cost or routine. |
Seaford1147.50 |
12-05-2021, 08:31 AM | #5 |
Rainbow Racer
1008
Rep 2,539
To get the most out of a level 2, yes a 60amp is ideal (80% rule) to get up to 11kw @ 48amp.
However, the difference like mentioned above wouldn't matter too much if the car is charging over night. Approximate values based on amp: 20 amp = 4.8kw 30 amp = 7.2kw 40 amp = 9.6kw 50 amp = 12kw In other words, on a level 2 40amp outlet the car will charge up to 9.6kw per hour, adding 32.2 miles of range per hr if you have a range of 270 on your particular driving cycle. This figure will vary depending on prior driving, and does not dictate the next drive cycle, think of like average mpg on one tank vs another. I took BMWs 270 range (found on a separate section on BMWusa where it lists the edrive40 at 275miles vs the M50 at 270miles when both are equipped with 19" wheels), divided it by the usable battery range of 80.5kw, and ended up with 3.354 miles per kw. Take 3.354 and multiply it by 9.6kw to get miles per hour for charging. Hope this helps? All above are approximate values based on ideal charging conditions. Side note, with FPL charging a combined rate of approx 11 cents/kw, from 20-80% would only cost less than $5.50 for me...literally it would take 9-10 charges to equal 1 gas tank fill on my M4cs... To answer your question on which product to use (the BMW supplied one or the wallmount unit), the biggest question would be where would your plug be installed? If outdoors, than the wallmount unit is better for security reasons vs having an opened NEMA 14-50 plug readily available outside for someone to steal your electricity. If it's in your garage, I'd just stick with the BMW supplied one. The wallmount units likely have more features though (like how much you are actually drawing etc etc...) that is easier to read vs going into the i-drive system menu's, and perhaps are aruguably more "stable" at charging speed. Additionally, you'll have the added benefit of having two units (use BMW's supplied for road trips, and the wallmount for when you are at home). I'm going to stick with BMW's supplied unit for now and see how stable it is and if it will fit my needs. I'm not really sure what the max charge is on that unit and if it limits it to lets say 9.4kw vs the full 11kw that BMW says the i4 can charge at on a level 2. Last edited by spool twice; 12-05-2021 at 09:00 AM.. |
Seaford1147.50 ghaffari461128.00 |
12-05-2021, 09:10 AM | #6 | |
I know a thing or 2 about a thing or 2...
3101
Rep 3,470
Drives: E36 M3 Coupe, e39 M5, i3s
https://www.psegliny.com/saveenergya...ev/smartcharge
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) |
12-05-2021, 10:04 AM | #7 | |
Rep 133
Second, if you look at the iX, it's even stranger. They list the expected hit going from a 20" to a 21" wheel. But then you find the range increases going from a 21" to a 22" wheel. Really? How does that work. I'm a bit skeptical of some of this info. |
12-05-2021, 10:51 AM | #8 |
Rainbow Racer
1008
Rep 2,539
On some Facebook groups, the type of 19" wheel also impact range. Probably has to do with tire type, weight, and how aerodynamic they are.
On the M50, the 20" wheels have an even bigger impact according to BMW. Wheels matter with EVs |
12-05-2021, 12:07 PM | #9 | |
4654
Rep 6,033
As for the 22", check the specs for the manufacturing process. It may be that the 21" and below are pressure cast, while the 22" may be forged, allowing for a lighter weight design. I don't have the facts to support this, but it is a plausible theory from my experience with product development, pending learning the actual relative weights.
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner Last edited by Sportstick; 12-05-2021 at 12:42 PM.. |
Ken732.00 |
12-05-2021, 12:09 PM | #10 |
Rep 133
Definitely, that’s always been the case with EVs I’ve owned. But there’s something that doesn’t seem right & inconsistent with BMW’s range hit estimates. I guess we’ll see when they actually hit the road.
12-05-2021, 02:47 PM | #11 | |
Rainbow Racer
1008
Rep 2,539
Hope the specs are published soon. I know on the F8x M3/M4, the 18" standard wheels are heavier than the optional 19" wheels.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
12-05-2021, 06:52 PM | #12 |
148
Rep 481
Great responses!! Thanks a million. Ill try the supplies accessories before buy-ing the wall box
Seaford1147.50 |
12-05-2021, 06:54 PM | #13 |
148
Rep 481
I had solar panel installed in 2010. Was going to get an I3 but hurricane Sandy changed my plans. The I4 will be interesting
12-06-2021, 06:13 AM | #15 |
Rainbow Racer
1008
Rep 2,539
The double five spoke designed 18" on the i4 M50 looks okay to me:
https://www.bmwusa.com/build-your-ow...xterior/wheels
-Loe P.-
12-06-2021, 07:09 AM | #16 | |
Rep 133
12-06-2021, 08:05 AM | #17 | |
Rainbow Racer
1008
Rep 2,539
***EDIT*** nevermind I just viewed the edrive40 18" wheels. Looks like just darker finished 18" wheels that are available on the M50 where they are more machined aluminum/polished
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 Last edited by spool twice; 12-06-2021 at 08:14 AM.. |
12-07-2021, 11:15 AM | #18 |
Rep 42
Biggest difference will be weather resistance and security in the sense on how the charger is secured to the wall and if it is installed indoors or outdoors.
The Wall charger might have some smart functions I would assume also. Finally, make sure you pick the correct NEMA adapter for the plug you have available. |
12-07-2021, 12:01 PM | #19 |
Rainbow Racer
1008
Rep 2,539
Does anyone have the specs of BMW's NEMA 14-50 adapter? Trying to find out if can 240v/48a or if its possibly a lower amp?
If the i4 can support 11kw with a 240v/48a outlet, I'd at least like to know if the supplied adapter can supply the full 11kw charging or if I'd need to purchase a seperate unit (my OCD...)
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 Last edited by spool twice; 12-07-2021 at 12:17 PM.. |
12-08-2021, 12:34 PM | #20 |
Rep 16
Most likely not 48A. There is a code limitation, a derating value, that requires 48A to be supplied via 60A circuit. NEMA 6-50 and 14-50 outlets are limited to 50A. This is outlined in the ChargePoint EVSE manual. Fora 50A circuit the max load is 40A charging. For 40A circuit the maximum load is 32A charging.
12-08-2021, 03:38 PM | #21 | |
Rep 42
12-08-2021, 04:54 PM | #22 |
Rainbow Racer
1008
Rep 2,539
thanks! great chart!
So there looks to be another advantage in getting a wall unit, the benefit of using the full 48A/11kw charging system. Looks like at 60% (SOC 20% to 80%), it would take 5hrs 2 mins @ 9.6kw, but it would take 4hrs 23 mins @ 11kw. 39 mins is a sizable gap which will only widen if your charging > 60% But I suppose if it's only for overnight charging that it wouldn't matter too much.
-Loe P.-
