BMW M3 and M4 - The Icons
Technical Sections Suspension / Brakes / Chassis
      11-23-2021, 06:35 PM   #1
evoi19
evoi19's Avatar
1527
Drives: 2022 G80C
Brake Swap Compatibility
Thought I'd ask to see if anyone knew but may call up Brembo for a definitive answer.
I have an e90 with a Brembo big brake kit and I'm getting ready to sell her soon, but wanted to see if the calipers and rotors would be interchangeable and can be swapped over to the g80. I'm assuming the caliper should fit with new SS brake lines fitted. The rotor i'm not sure of though. Would the 5x120 bolt patter on the e90 interfere with the g80?
If it does work, then figuring out if the stock wheel's offset would clear the calipers would be the next question!
Anyone venture a guess?
      12-18-2021, 11:01 AM   #2
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
The G80 wheel bolt pattern is 5 X 112.
g80
