10-21-2021, 08:50 AM | #1 |
1363
Rep 2,495
M Technology Pack on i4
So I am getting close to finalising a spec, and I noticed that after moving to the 19"s from the 20"s that I now cannot get the M Technology Pack which has better brakes and better battery cooling.
Anyone else noticed this?? So frustrating... might just have to order the 20"s and buy more narrow tyres for the wheels. The pack detail: ....features increased heat capacity of the braking system and the cooling system that guarantees a long-lasting high performance under extreme driving conditions (similar to motorsport) (especially in combination with high outside temperatures). Includes upgrades for the drive train cooling system and the M Sport braking system. Available with 20" 868 M Double-spoke Bi-colour Alloy Wheels on the M50 model.
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
10-21-2021, 08:53 AM | #2 |
6603
Rep 6,700
Brakes probably don't clear the smaller wheels. Not uncommon.
SteveinArizona3086.00 JMi3S20190.00 |
10-21-2021, 09:17 AM | #3 |
Rep 253
I'm not sure what the cooling is. I suspect this might be sadly a cut and paste from the MTech pack on other cars where there is an additional oil cooler. I've not seen anything on battery cooling.
10-21-2021, 09:22 AM | #4 |
1363
Rep 2,495
I guess "Includes upgrades for the drive train cooling system" means battery cooling.
BimmerBahn441.00 |
10-21-2021, 09:49 AM | #6 |
1363
Rep 2,495
Thanks - that's good to know, although I now want the larger brakes
11-02-2021, 06:29 AM | #7 | |
Rep 4
11-02-2021, 09:01 AM | #8 | ||
1856
Rep 1,964
Arctic Metallic\CF Splitters,Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1\M-Performance Brakes\Cobb Tuned\xHP Flash ->
12-08-2021, 01:06 PM | #11 |
1166
Rep 2,180
12-08-2021, 01:26 PM | #12 |
Rainbow Racer
1008
Rep 2,539
seems like this package was recently renamed....now it's called "high performance tire package"...at least in the US.
The brakes should be the same as the M340/M440i, which are M-sport brakes but not as large as the M-performance accessory brakes.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
12-08-2021, 05:01 PM | #14 |
1166
Rep 2,180
The M Technology package brakes are the same as the M Performance brakes -up-sized calipers, 374mm rotors- except that the M Performance rotors are dimpled and slotted.
12-08-2021, 05:10 PM | #15 | |
Rainbow Racer
1008
Rep 2,539
The larger brakes could possibly be the other reason why going from 18 to 19" wheels is seems to only be a 25 mile range hit on the edrive40, but going from 19 to 20" is almost double the range hit on the M50 because of the heavier brake hardware.
-Loe P.-
12-08-2021, 09:20 PM | #16 |
Rep 188
Wider, stickier, heavier tires probably cause most of the drop when going to the 20" wheels. Brake weight has little impact on fuel economy since it's all closer to the hub. Calipers aren't spinning, too. The wheel and tire weight matter more. I guess it all adds up.
The new text on the US website is: "High Performance Tire Package $2,500 Enhance the aggressive appeal of your vehicle with a body-colored rear spoiler, increased braking capacity for extreme driving conditions, and wheel arch moldings on the rear axle. Also included are wider, high-performance tires offering improved traction, reduced stopping distance and enhanced dynamic response." Nothing about cooling anymore. So is 2500 worth it for upgraded calipers and massively upgraded wheels and tires? If you want better handling, I'm guessing a huge yes. Braking doesn't matter so much because it's an EV, but extra capacity is a good thing. |
12-08-2021, 10:17 PM | #17 | |
1856
Rep 1,964
My mileage requirement is 250 so anything extra is a plus. Also I suspect in Eco mode mileage will be better. I think, and don't quote me, the front motor is not engaged for drive in Eco mode. Since it also doesn't have permanent magnets it should freewheel with out a lot of losses.
12-09-2021, 07:34 AM | #18 | |
I know a thing or 2 about a thing or 2...
3101
Rep 3,470
Drives: E36 M3 Coupe, e39 M5, i3s
M Technology package Increased capacity of the braking system for improved performance under extreme driving conditions, particularly when driving in very high temperatures. Doesn't mention cooling per se, but it does say improved braking under high temperatures.
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) |
12-09-2021, 10:38 AM | #19 | |
Rep 188
I'll likely use one-pedal driving 95% of the time. |
Haywood3100.50 |
