09-17-2021, 04:27 PM | #3 |
Rep 21
Nice!
What system did you go with? Is it all from Veleno? The dual tips? Do you have more pictures of the system straight from behind under the car? Also how did it fit? Especially the Y pipe? The one I found online for now only is to 40i that's why I'm wondering. Looks great! |
09-17-2021, 05:17 PM | #4 | |
Rep 122
It's a dual valve system with the custom setup where GFP ( European ) is deleted. Resale model will have a remote but mine is wired specially and valve system will be programmed into DME and will work as OEM and have full open vales as BMW programming meaning cold start and over 4000 something rpm. Plus I'm getting ECU tune as well at the same time. I'll get photos when the production system is installed that I can share. |
09-18-2021, 10:03 PM | #7 |
Rep 122
Will send later. Exhaust Programming is still going on the codes for 40i doesn't work on 45e so they are still figuring it out. But will send. Cold start has only 2 second open vales and then closes. As I didn't want remote for the vales it's built into DME but we have programmed it slightly different. Instead of open valves at around 4000rpm the valves will open at 2800rpm during acceleration.
11-09-2021, 08:06 PM | #11 | |
Rep 122
