BMW M3 and M4 - The Icons
Classifieds Sponsors Classifieds Suspension / Brakes / Chassis / Spacers
      09-14-2021, 10:14 AM   #1
IND-Distribution
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
IND | Fall-Line Motorsports G8X M3 / M4 Front Monoball Conversion
MADE IN THE USA.
Fall Line’s monoball spherical bearing conversion kit transforms the front steering and suspension feel of the M3/M4. The factory rubber bushing is very large, and is prone to substantial deflection under load, as the car is put through its paces. Deflection of the bushing can create unwanted geometry change, steering wobble under braking, and even hysteresis of the thrust arm.
The bearing’s housing is precision machined from aluminum, to create a rigid part that allows for the M3/M4’s thrust arm to move smoothly through its range of suspension travel. The improvement in steering and suspension feel is immediate and truly enhances the personality of the new G8x.
Product Details:
  • Fits G80 M3 and G82 / G83 M4
  • Incorporates hard coat clear anodized finish
The Fall-Line Motorsports G8X M3 / M4 Front Monoball Conversion may be viewed at the following link to our online store:
https://ind-distribution.com/product...all-conversion
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      06-05-2022, 11:30 AM   #2
FLOSS M
///M3
FLOSS M's Avatar
386
Drives: 22 M3 X-Drive
Will this work on xdrive models ?
      06-07-2022, 10:19 AM   #3
IND-Distribution
9587
Yes, they are confirmed to fit xDrive models.
      12-04-2022, 11:55 AM   #4
dirtyfreebooter
dirtyfreebooter's Avatar
Drives: Vespa
do these require a press to remove the old brushing? and install the new one?
      12-05-2022, 09:06 AM   #5
Digitalfujjjrel
Drives: BMW 330E BMW M3 CS
I hope not. I ordered mine 3 days ago.
      12-05-2022, 10:50 AM   #6
dirtyfreebooter
Drives: Vespa
videos like this ->
for F8x which uses basically the same arm, seem like you need a press to remove the stock one and even to insert the new monoball...
i think if i go this route i will just buy new arms (they don't have brushing in) that way its easy to return to stock if its not working out. and maybe find a shop that will press them in for me if need be.
seems like these are the arms, but i am not 100% sure
      01-18-2023, 01:37 AM   #7
wavyyyy
Drives: M2C
2023 bmw m3 6mt  [0.00]
I wonder if there are any plans on selling these pre installed in control arms?
Limegrntaln13472.00
      01-18-2023, 02:04 AM   #8
Limegrntaln
Limegrntaln's Avatar
Drives: 2022 DG/BLk xDrive M4C Wk 34
This
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou
      01-23-2023, 01:21 AM   #9
Em3comp
Em3comp on Ig
Em3comp's Avatar
16
Drives: 2021 M3 Competition
im thinking of buying these
Ig:Em3comp
      01-23-2023, 09:26 AM   #10
IND-Distribution
9587
Not at the present moment.
      04-21-2023, 04:16 PM   #11
STALKER
169
Drives: 997.2 GT3, Golf R
Are these sealed like the Dinan ones, or will they require maintenance? Thanks
GTS Daddy372.50
      05-08-2023, 01:44 PM   #12
breezyrc15
breezyrc15's Avatar
Drives: 2024 G82 M4CX
I believe these are not sealed. You can see the Dinan ones have a sealed rubber boot in my pics below.
      05-08-2023, 01:56 PM   #13
breezyrc15
breezyrc15's Avatar
IND-Distribution
do you have a link to a street-car version which has the monoballs sealed with rubber boots? or do we call in and ask for that on the order?
GTS Daddy372.50
      05-08-2023, 02:56 PM   #14
GTS Daddy
#Driver
GTS Daddy's Avatar
373
Drives: '23 G80x
Originally Posted by breezyrc15 View Post
IND-Distribution
I wonder what the concern is with debris getting in there?
2016 Focus RS - ende | 2017 718 Cayman - ende | 2007 911 C4S - ende | 2017 Macan - ende | 2015 Macan Turbo - ende
2023 M3xdrive | 2020 Macan
insta: gtsdaddy
      05-08-2023, 04:55 PM   #15
breezyrc15
breezyrc15's Avatar
Race cars don’t have the rubber boots because they don’t have to deal with the same longevity concerns Street cars have. The rubber boots/seal ensures longevity and minimizes the maintainence of the mono balls.
      05-08-2023, 11:14 PM   #16
IND-Distribution
9587
IND-Distribution
We do not have this product with dust boots currently. FLM has not incorporated them into their design.
g80
