BMW 5-Series (G30) Forum Mechanical Maintenance - Break-in, Oil, Fluids, Servicing LL17 Oil?
      07-02-2021, 07:27 PM   #1
kosmokratur
Drives: 2018 M550, '00 750, '97 540,..
LL17 Oil?
Hi everybody.
The dealer did an oil change for my 2018 M550 a few days ago. When filing away the receipt I noticed that they used "LL17 0W-20" (part number 105 83-21-5-A42-D12). I was under the impression that the 550 required the LL-01 in )W30. Did the factory upgrade the specs? I'd hate to think my dealer dropped the ball on this.
      07-06-2021, 09:46 AM   #2
CHECKERED
ex deus machina
CHECKERED's Avatar
Drives: G30, F15, Audi S4
that's not the correct oil, unless the invoice is wrong
I looked extensively into this as I'm planning to do my first oil change
factory fill is 0W-30 and that should be used, the 20 weight is too thin for the high oil temps on the N63R
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK
Gone: E92 335i N54 468rwtq
      07-08-2021, 07:30 PM   #3
kosmokratur
Weird
The dealer confirmed (in writing) that it is approved. I'm still not certain I want to keep it in there, though.
      07-15-2021, 09:42 PM   #4
kosmokratur
More info...
I contacted a well-regarded BMW guru who did not recommend a specific oil, but did emphasize the need for more frequent oil changes. I then did the unthinkable and called BMWUSA. The rep took a couple minutes but ultimately he was able to confirm that the LL17 is now approved for the N63. LL14 is still a no-no. So I guess I'll leave the LL17 in for a few months and spcifically request the LL 01 after that, at least until my CPO warranty expires.
admranger2984.50
      07-30-2021, 09:04 PM   #5
430Scud
430Scud's Avatar
253
Drives: M550iX,430 Scud,E39 540Msport
Since 2020, I am told the M550iX owners manual states either LL-01 FE oil 0w-30 or LL-17 FE 0w-20 is approved (apparently retroactive to the previous N63s). But agree I would lean toward the LL-01 FE 0w-30. In fact out of warranty, I would use the LL-01 5w-30 or 5w-40 which has a much higher HTHS (high temperature, high sheer) rating. The "FE" versions I believe, are optimized for fuel economy.
HTHS of LL17-FE is equal or greater than 2.6 Only available in 0w-20
LL-01 FE is equal or greater than 3.1 Only available in 0w-30
LL-01 is equal or greater than 3.5 Available in both 5w-30 and 5w-40 note that both oil viscosities will be similar, in order to meet the LL-01 rating. So that means the 30 rated oil will be at the higher end of 30 weight oils, while the 40 rated oil will often be on the thinner range and still be considered a 40 weight oil.
Note that higher viscosity range, usually (but not always) correlates to higher HTHS. But you only know for sure by reading the specification sheets for each individual oil. If it has the LL rating, you know it at least meets the minimum HTHS ratings above.
      08-29-2021, 05:05 PM   #6
edycol
Drives: 2011 328i xDrive
Once you are out of warranty move to Castrol 0W40.
N63 doesn't require new updated LL01 (2018 update).
Until then use LL01, preferably Pennzoil Platinum Euro 5W40 or even better Motul 5W40 X-Cess GEN2.
430Scud253.00
      11-01-2021, 07:31 AM   #7
mishka69
Drives: BMW 2008 E60 535i
What about 540i 2017 B58 engine. Can i use 0W20 or need LL01 0W30
      11-01-2021, 10:32 AM   #8
430Scud
430Scud's Avatar
253
I would use the LL-01FE over the LL-17, given the choice between the two. Out of warranty consider an LL-01 oil, or the Castrol Edge 0w-40 as recommended by edycol
      11-02-2021, 12:21 AM   #9
edycol
Are you out of warranty? If so go LL01 or LL04. LL04 will be heavy version of LL17FE. You can get Pennzoil Platinum Euro L 5W30 for $22 for 5qt in local Wal Mart. Excellent oil.
If LL01 go Motul X-Cess 5W40 GEN2, Pennzoil Platinum Euro 5W40.
Castrol Edge 0W40 is exceptional oil but doesn't carry anymore any BMW approvals due to change in requirements by BMW. It is good choice but keep OCI at 5-7.5k with this oil due to bit higher oxidation as a result of more "true" synthetics in the oil.
If you are still under warranty and manual says you can use LL01 FE go Motul specific LL01 FE 5W30.
430Scud253.00
      01-15-2022, 07:04 PM   #10
kosmokratur
I have oil analysis results. I sent a sample of my LL17FE oil, in service for 7500 miles, off to a lab, and asked them if the results would be consistent with a 11,000 oil change interval. In brief, they observed no problems with the sample and proposed stepping up to 9500 miles... if that analysis is OK, they said to give 11K a shot.
I am not really planning to do stretch my intervals any further, but it is encouraging that, at least with this particular car, the factory recommendation seems to be plausible.
      01-15-2022, 07:14 PM   #11
H_T
H_T's Avatar
Drives: 2021 m550i
2021 BMW m550i  [0.00]
Thanks for the update. I suspect the results would be different here in Florida where the temperature is over 90F, 8 months of the year.
What percent of your driving is city vs highway?
      01-16-2022, 09:01 PM   #12
kosmokratur
I'm out in the country; no more than 5-10% city usage.
Lots of hills, though!
H_T152.00
      01-17-2022, 01:52 PM   #13
430Scud
430Scud's Avatar
253
Ambient outside temperature shouldn't make too much of a difference, as the oil cooling and water cooling systems will regulate the engine temperature pretty consistently.
Driving type and total miles is more likely to have an impact.
      01-17-2022, 02:33 PM   #14
H_T
H_T's Avatar
Drives: 2021 m550i
You would think that, but the constant heat & humidity here does have damaging environmental effects on other products, like paint and plastics. It feels like 105-110f. I hear the cars' fan running consistently in the summer vs the winter (75-80f ) months
      01-17-2022, 05:55 PM   #15
edycol
Nope.
Ambient temperature is not big factor in cooling. In degradation of plastic bcs. humidity might be, but that is diff issue.
Altitude is what matters.
Your engine will struggle more to cool off at Vail Pass that is at 10,500ft here in CO at 50f than in FL at 100f.
Just bcs. fan is running, doesn't mean there is cooling issue.
430Scud253.00
H_T152.00
      01-31-2022, 06:57 PM   #16
430Scud
430Scud's Avatar
253
I don't doubt that your LL17FE 0w-20 oil can go the distance. The point of edycol and I recommending an alternate oil, is the LL-01 oils have a higher HTHS and properties that potentially can give you greater protection to your engine and turbos. So even though LL17FE is staying in grade/viscosity and additives are still within its original specifications, those properties are not as good as what an LL-01 oil offers.
      01-31-2022, 08:40 PM   #17
edycol
Blackstone always recommends longer OCI.
      02-02-2022, 01:43 AM   #18
kosmokratur
Thanks. I have gone back to the LL01 (still under CPO warranty) and I don't plan to stretch it past 5-6K miles again.
      03-03-2022, 05:30 PM   #19
F90-EOP
Drives: BMW
Dealer used LL17 0W-20 in 750
Last week my local dealer used LL17 0W-20 in my 750. When I asked why not LL01 0W-30 as specified for N63 V8s I was told they use bulk 0W-20 in everything and no one else has questioned it. After I asked for a document showing that BMW approved using 0W-20 for N63 V8s they called me back the next day to say they would change the oil & filter again using LL01 0W-30 from bottles. The oil change redo was done this week.
2022M550i3034.00
      03-03-2022, 06:08 PM   #20
2022M550i
2022M550i's Avatar
3034
Drives: 2022 M550i, 2015 Viper
Listed under the hood
H_T152.00
      03-05-2022, 05:37 PM   #21
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
Since you seem to be on top of oil info, do you happen to know what the Amsoil euro 5w-40 or 5w-30 look like as an oil for the M550? I like boutique oils (kinda).
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
      03-07-2022, 01:50 PM   #22
430Scud
430Scud's Avatar
253
You should be asking edycol, as he is much more versed than I.
Looking at the spec sheets, neither has BMW approval, though Amsoil claims they meet either the BMW LL-04 (5w-30) and LL-01 for the 5w-40, neither spec applies to the G30. Both have higher HTHS than BMW requirements at 3.6 and 3.8 respectively. I'd probably lean to the 5w-30 only because I prefer a thinner oil, as long at the HTHS is high, which it is here.
admranger2984.50
5post
