06-29-2021, 01:01 PM | #1 |
Rep 75
Drag strip mod recommendations
I was trying to find the answers to my questions in the forum, but since I had a few different ones, I was getting a headache searching through them all. Didn't help that all the terms are pretty generic and returned a lot of results.
I just started going to drag strip near me and seeing what I can run. Been trying to learn the car to get the best time. It's a stock '18 Comp and out of about 6 runs, the best is a 11.2. I was looking for some recommendations on some tweaks to make to get it down a bit. I forgot to charge my dragy, so it was off the track times. It was with the OEM Pirellis and with almost a full tank of gas using LC. I know, I wasn't thinking at the time and didn't plan well Here's what I was wondering: 1. I saw that Shell premium gas seems to be recommended. Is there a max octane number to stay under to make sure you don't do any damage? If you can go over the regular pump gas, do you mix with race fuel or use some type of additive? 2. I know the M5 4WD is something like 60/40 to the rear, so does it make sense to put drag radials or something more sticky on just the rear, or across all 4? I've seen people mention 20' and 19'. What size(s) have people had success with? 3. What drag radials have people had success with? Seems like most people recommend the MT ET or R888R? Sorry for all the questions, but just trying to see what people have had luck with and see what I can get it to do. Thanks and any suggestions are appreciated! |
06-29-2021, 05:12 PM | #2 |
3323
Rep 8,083
You should be cracking 10's with a comp iirc. I'm doing 11.1 with a non CP, on Pzero's, on a 85 degree day.
I think r888's would be overkill for someone who is stock. The car doesn't have any problems hooking out of the hole in stock form. |
06-30-2021, 10:50 AM | #3 | |
Rep 75
What have you used for gas on your runs? |
06-30-2021, 05:49 PM | #4 | |
3323
Rep 8,083
93. I actually can't remember how much gas i had in the car at the time. Do you have your timeslip from the track? |
06-30-2021, 09:11 PM | #6 | |
Rep 75
https://f90.bimmerpost.com/forums/at...1&d=1625105406 |
06-30-2021, 09:25 PM | #7 |
3323
Rep 8,083
hmmm too lazy to post a timeslip pic but i'm reading mine..
.434 1.686 4.680 7.170 98.57 9.317 ET 11.12 MPH 125.4 I'm trapping 3mph faster than you. You're letting the car shift itself right? |
06-30-2021, 10:37 PM | #8 |
Rep 142
my times on my dragy run are identical to Trevor's except I let out early so my 1/4 was 11.3 because I wasn't at a track and 100 on the feeder is fast enough even in the middle of the night. I have a 19 non comp with heavy everything including my fat 250 lb ass.
07-01-2021, 01:33 AM | #9 |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
I'm heavily modded and tuned but my best times have always come via launch control and let it handle 1st 3 shifts and I take over 3rd to 4th and 4th to 5th and let 5th run until 1/4 mile. I trap around 136-139 depending on weather. I normally shift around 5500 rpm.
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
07-01-2021, 08:07 AM | #10 | |
Rep 75
https://f90.bimmerpost.com/forums/at...1&d=1625144812 |
07-02-2021, 01:12 PM | #12 |
Rep 75
07-02-2021, 05:40 PM | #13 | |
MFJWADE
120
Rep 351
2018 M5 Singapore Grey CCBs/Utku Noa E45 ECU/xHP TCU/PG-Intake/PG-Lower Downpipes
07-03-2021, 12:07 PM | #14 |
1105
Rep 1,607
It's should help, I'm tuned and run between e46-48 without any issues.
GT
07-03-2021, 09:37 PM | #16 |
1105
Rep 1,607
Without tune as long as u don't have loss of power or misfire u should be fine.
GT
07-15-2021, 06:41 PM | #17 | |
Rep 75
Now that that's out of the way, I went to the track last Friday and when I did the correct LC, I couldn't get any traction. I'm not sure if it was the track that particular night, but it was after sunset and the temp was probably around 80-85. Should I now consider some type of street slick to get traction with the LC? If so, what types are people running successfully with? I know the Toyo R888's are mentioned and I went to a local wheel/tire place and they were thinking some Nitto's. They mentioned NT05 in the front and NT555RII in the rear. These will likely only be at the track, but what to make sure I don't run into any rubbing issues, so what are the recommended sizes? I've seen some people mention using 275 square, but others 305 with 19's. Just seeing what's out there for recommendations. Thanks all! |
07-15-2021, 07:55 PM | #18 | |
3323
Rep 8,083
again, if you are stock, i dont really see how you could be having traction issues.. the car dead hooks out of the hole.. even on pzero's which everyone on this forum hates.. |
07-16-2021, 11:19 AM | #19 |
MFJWADE
120
Rep 351
07-18-2021, 12:51 PM | #20 |
294
Rep 456
I always ran E30-E50 without any issues stock. Definitely noticed improvements, measured by dragy.
2018 BMW M5
2018 Porsche GT3 2023 Porsche Macan S 2023 Porsche 911 Turbo S |
07-18-2021, 12:53 PM | #21 | ||
294
Rep 456
2018 BMW M5
07-18-2021, 01:18 PM | #22 |
Rep 612
I would stay away from the NT555R2. I ran them on all 4 corners of my E63 275/35R20 front and 305/30R20 rear and I wasn’t impressed. Traction was no better than MPS4S, sketchy in rain, no rim protection, and overall rough ride. My suggestion to add grip would Toyo R888R in 285/35R20 square
