BMW 2-Series Gran Coupe
BMW 1 Series Forum Second Generation (F40) BMW 1 Series (F40) General Discussion
      06-27-2021, 03:55 AM   #1
cygbmw
Drives: BMW 118d
Trunk panel removal
Hello!
I'm trying to remove the left panel in the trunk of the car, to access the amplifier. I did remove the plastic "things", unscrewed the Torx, removed the bottom panel and the plastic one. However the left panel is somehow still blocked. There's something I am missing? I can't find any info (video, photos) online. I can find info about other models and the operation doesn't seem so difficult.
Thanks.
      08-22-2021, 11:42 AM   #2
vancouvergy
Drives: m2
Originally Posted by cygbmw View Post
Hello!
I'm trying to remove the left panel in the trunk of the car, to access the amplifier. I did remove the plastic "things", unscrewed the Torx, removed the bottom panel and the plastic one. However the left panel is somehow still blocked. There's something I am missing? Speed TestI can't find any info (video, photos) online. I can find info about other models and the operation doesn't seem so difficult.
Thanks.
hey bro listen if you want to solve a problem like this go to your closest mechanic ,, this is cannot be solved on the internet even if you find the answer it still gonna be diffcult for you unlike the specialist
have a goo day
      04-02-2024, 06:12 AM   #3
awillms
Drives: Mec
Candy Crush said:
Hello!
Thanks.
In some car models, there may be additional panels or covers that need to be removed before gaining access to the desired area. These panels are often designed to blend with the interior, so they may not be immediately obvious.
      04-02-2024, 11:25 AM   #4
cjn
Drives: 2021 F40 M135iX
Hello!
Thanks.
Here you go:
bmw
