05-03-2021, 07:11 PM | #1 |
Rep 100
F31 - boot trim removal
Hi all,
Does anyone know of a guide to removing the boot/trunk trim from the touring? I've purchased the separator bar thing and associated boot/trunk floor fixings but upon trying to remove the boot/trunk trim it seems that almost everything - including the plastic cladding around the hatch opening, even going up the sides - has to come out. I need to rivet fixings to the metal of boot floor but removing vast amounts of BMW is not what I expected. I'm that close to paying BMW to do it. Any help would be appreciated. ta
"Shego" F31 335d xDrive MSport Touring since Feb '20
"Kitty" E90 325d MSport from June '15 - Dec '19 |
05-15-2021, 09:39 PM | #2 |
377
Rep 421
Drives: 2017 F31 328dx
Hardest part for me was the top part on the sides. I never figured it out but was watching a video the other day and found this out. To remove the top part on the sides you have to remove the C pillar by removing the little Air Bag cap. There is a screw behind that. Everything on the sides is pretty easy after that. You'll need a torx bit to remove the screws hiding under the cargo hold downs.
Check out 7:38 for a quick shot. Last edited by shiftdnb; 05-15-2021 at 09:46 PM.. Reason: Added Video |
07-07-2021, 03:29 AM | #3 | |
Rep 100
shiftdnb376.50 |
06-10-2023, 08:23 AM | #4 |
Rep 100
Had some issues so finally want to do this - and still can find no step by step guide.
Anyone?
