05-02-2021, 04:21 AM | #2 |
3847
Rep 1,675
Drives: M2 CS | M135i
Interesting… Maybe an attempt to reduce CO2 emission?
I will try 2.4 instead of 2.6. Maybe the car will be a bit more composed on bad roads.
2020 M2 CS DCT
2021 M135i xDrive ex: 18 M3 DCT ZCP | 15 M3 DCT | 11 M3 Coupe 6MT ZCP | 07 M Coupe |
Ilikemike254.00 |
05-02-2021, 11:02 AM | #4 | |
3847
Rep 1,675
2020 M2 CS DCT
05-02-2021, 05:21 PM | #5 |
254
Rep 551
Interesting, my last car was the M2 C (23020), which also ran PSS, and the tire pressure listed on the label at the bottom of the door sill was 32 PSI which is exactly the same as my CS. It must have something to do with European requirements vs Canada... or as mentioned earlier, fuel economy ratings.
05-02-2021, 05:37 PM | #6 |
Rep 201
It's just a baseline anyway. I like 35f/32r.
Larger tires require less air and the rears don't work as hard laterally. Lower PSI also helps with launch.
2021 M2C, HS, 6MT, ZED, 763M w/spinners, AA single, AA axle back, Turner High Kick, Turner shifter support, M pedals, honeycomb reflector delete, BC Racing DS series
05-02-2021, 06:39 PM | #7 |
4610
Rep 4,708
In the CS manual there is a lot of detail about tire pressure with C and CS. Pressure is different depending on intended speed as well. I think under 100mph and over 100mph
05-02-2021, 06:58 PM | #8 |
254
Rep 551
05-02-2021, 09:18 PM | #9 | |
6571
Rep 3,087
Drives: M2 CS, 18 Vantage AMR, 00 WRX
Then again it's 2.6 2.6 here for Cup2Cs. Who knows? |
05-03-2021, 10:28 AM | #10 |
254
Rep 551
My CS sticker. 2.6 bar = 37.71 PSI, assuming the 2.6 bar is cold temp it seems a bit odd I'm at 32 PSI or 2.21 bar... I wasn't provided with a CS manual.... just a M2 manual. Last edited by Ilikemike; 05-03-2021 at 11:55 AM.. |
05-03-2021, 01:15 PM | #11 |
In the Details
1812
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
I set literally everything I own to 35psi cold in all 4 tires (except for HD trucks) and its always been just fine.
Unless you're on track (setting hot temps, btw) don't sweat the small stuff. |
