04-19-2021, 08:22 AM | #1 |
Rep 60
Cabin Air Filter Issue
Have a 2012 535 I Xdrive - Went to replace my Cabin Air Filter this weekend, when I took out the old Air filter (installed by a BMW specialty shop) there was only 1 filter - I was under the impression there should be 2 filters? When I went to install 2 filters back in, I could only fit 1 no matter what I did - Guessing the BMW tech had the same issue - These are non OEM Hengst E2978LC-2 filters - A few questions
1- Should there be 2 filters??? 2 - Should they fit easily?!?! 3- Did I buy the wrong filter??? If so would the MAHLE LAK 467/s be correct or should I waste the $$$ at BMW Any help is really appreciated.. Thanks! |
04-19-2021, 09:47 AM | #3 |
4489
Rep 7,532
Do they look like this?
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
04-19-2021, 12:24 PM | #4 |
Rep 60
Thank you both! I didn't realize there were two separate compartments - 20 minutes later and I'm all set! Looks like the filter in the back hasn't been changed in who knows how long - It was nasty - Thinking the Mechanic who changed my filters last didn't have a clue - But from now on I'll do it myself
Thanks again! |
04-19-2021, 03:21 PM | #5 |
4489
Rep 7,532
Thanks for the update...glad you got it all worked out.
04-19-2021, 05:46 PM | #6 |
1306
Rep 2,591
The filters are also directional. If they have a tab, the tab should face TOWARDS direction of travel (aka nose of car). If they do not, the arrow should face AWAY from direction of travel (aka trunk of car). There's a lot of bad info on the direction of the filters.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
OnlyGerman363.50 |
