04-16-2021, 09:49 PM | #3 |
Rep 389
Drives: Toyota Land Cruiser HE
I was going to do it but others have said the rears are too aggressive with stock 265/35
///Motorsports in my veins
04-16-2021, 09:55 PM | #4 |
564
Rep 464
Fronts will fit no problem, your rears may foul with the calipers because you lose 15mm backspace. No way to definitively know without trying.
You also add about 20+ lbs weight with that set. I love the look of those wheels, but more problems than solutions adding them to the CS. If you don't care about the OEM aspect, and like the look, some reputable companies make wheels which look like the 359, Apex has a set, I think VMR too. |
04-16-2021, 11:05 PM | #5 | |
1731
Rep 3,654
My service guy has a black comp wheel that has been on display for the last 8-10 years . it is just accumulating dust. I'll ask during my break in service if we can do a test fit. |
04-17-2021, 11:05 AM | #6 |
317
Rep 413
Not so sure that it will clear the brakes in the front...but highly probable they'll rub in the back.
https://f87.bimmerpost.com/forums/sh....php?t=1226960 |
04-17-2021, 01:28 PM | #7 | |
564
Rep 464
Since spacers up to 5mm have been fine on the front with no rubbing, 2mm is not an issue. OE front 763 - 9x19 ET 29 359 front - 9x19 ET 31 Rear, yes, may not work, but may be perfectly fine with a 5-7mm spacer - again, hard to tell without test fitting, because other than numbers, the shape and inside clearance of the wheel will determine fit here. Dynamic effect with the substantially lower offset in the rear - also hard to tell without trying it out. |
04-18-2021, 11:22 AM | #9 | |
317
Rep 413
As far as the rears go, the face of the wheel is pushed out 15mm - 359m are 19x10 ET +25 vs 763ms 19x10 ET+40. It's essentially the same as adding a 15mm spacer to the rear...I don't think you can fit that without rubbing with stock camber. |
04-18-2021, 05:30 PM | #10 | ||
2619
Rep 2,819
Drives: e82 1M, f87 M2cs
I currently have the track tires on my 1M so I could do a test fitment with the 359's on the CS.....but I don't think I have the time and really don't want to risk putting a mark on the caliper.
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
