BMW M3 and M4 - The Icons
G80 BMW M3 and M4 General Topics G80 M3 /G82 M4 versus...
      03-19-2021, 02:47 PM   #1
Sam CarLegion
Drives: M3 E90
10:36, M4 got eaten alive.
      03-19-2021, 03:30 PM   #2
02M3ForMe
4262
Drives: BMW
I don't see how anyone can come away after watching that and think that they're comparable in power in any way. Every time the M4 got traction, it reeled in the M440i hard. Big difference.
M4C puts down nearly 100 more hp to the wheels than the M440i does in crank hp. It's not close.
M3AWD3181.50
Puuhapete145.00
      03-19-2021, 03:40 PM   #3
M3AWD
M3AWD's Avatar
Drives: 2022 G80 M3 AWD
I hope you're not serious because the M4 showed that it's a MUCH faster car in Joe Achilles' video. Yes the xDrive on the M440i makes it launch faster and sometimes is enough for it to win a drag race but the M4 was reeling him in and showing the 100+ whp difference. Such difference should've been very obvious to the "reviewer" in the video posted by the OP.
Did you watch the 2nd run at 12:10? The M4 had a decent start and was clearly a couple of car lengths ahead at the 300m finish line so the difference will be even more obvious if this was a full quarter mile or 400m.
If you're trying to compare the launch of an xDrive M340i/M440i vs. RWD M3/M4 I'm not interested in that discussion. We can cross that bridge when the M xDrive M3/M4 are tested.
2022 G80 M3 Comp M xDrive
02M3ForMe4261.50
      03-19-2021, 04:58 PM   #4
DimM3
DimM3's Avatar
302
Drives: BMW X3 M40
Thanks!
      03-19-2021, 06:27 PM   #5
Bumpinjeep
Bumpinjeep's Avatar
Drives: 2023 M2
2023 M2  [8.00]
Enjoyed.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed
solstice5456.50
MoeMuc118.50
      03-19-2021, 07:02 PM   #6
m630
m630's Avatar
967
Drives: '22 X4M Comp / ‘22 X3 / f136
‘22 X4MC  [0.00]
      03-19-2021, 07:08 PM   #7
BluM4
Drives: Blue M4
Is the width of the G82 M4 rear the same as the regular 4 series? I believe the F82 is the same as the f32. It looks like it in the video.
      03-19-2021, 07:22 PM   #8
PeregrineFalcon
Drives: vw cc
No, both the F82 and G82 are wider than their base cars (front and rear).
      03-19-2021, 07:36 PM   #9
BluM4
Drives: Blue M4
Yeah, you are right about the F82. I remember this video:
I hope someone makes something similar for the G80/82.
      03-19-2021, 07:47 PM   #10
sensi09
30
Drives: .
That Joe achilles is alright. When I saw him on those carwow videos I wasn't a fan, but his videos are pretty good IMO.
He talks about about the front end grip. The M4 has a 275 front tire vs a 225 I believe for the M440. Wonder how much that front end grip is due to tire versus just the suspension setup.
      03-19-2021, 07:58 PM   #11
CanAutM3
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
The G8X also has a 1.4" wider front track than the G22. That is quite significant.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      03-19-2021, 08:53 PM   #12
solstice
5457
Drives: 2015 M3 6MT
I guess that settles that, does it feel like an M440i? Nope.
M440i, oh it feels heavy, understeer, understeer, it’s heating up and getting sloppy.
M4, the front end grip! Oversteer, the speed! Not one negative word.
Is it still a proper M3/4 that feel at home on a circuit? Sure seems like it.
      03-19-2021, 09:11 PM   #13
BluM4
Drives: Blue M4
I thought the new G8x has better traction using launch control. Looks like it really needs AWD to put all the power to the ground. I am surprised it actually lost one race to M440i and the other race was pretty much a tie.
      03-19-2021, 09:15 PM   #14
solstice
5457
Drives: 2015 M3 6MT
It has good traction but not nearly to overcome the gap to AWD. The M4 AWD should take off as a complete jackrabbit using the improved rear wheel traction and adding the front wheels.
And not even the AWD should be anywhere near putting all the power down from a standstill. Just as the RWD it will be controlled by LC.
      03-19-2021, 09:18 PM   #15
bri1042
bri1042's Avatar
5940
Drives: 2021 IOMG M3 6MT
At least not in that short run. It was a 5th of a mile and he wouldn't have needed much more space to come past.
The RS4 vs. M4 vs. C63 race showed the same results. AWD shows its value early, not late.
Edit: I've started to really feel that 0-60 runs and 1/4 runs are too short for modern cars to really shake out what they can do.
      03-19-2021, 09:32 PM   #16
solstice
5457
Drives: 2015 M3 6MT
Yes with overcome AWD I meant the actual launch. An AWD car jump off the line in a way a similar RWD front engine car can’t match.
      03-19-2021, 10:17 PM   #17
solstice
5457
Drives: 2015 M3 6MT
Btw this is just the kind of slow winding little circuit that is brutal to cars this large and heavy and mercilessly reveal the impact leaving them red faced with the pants down which is pretty much what happened to the M440i while real M..agic left the M4 standing proud.
      03-19-2021, 10:50 PM   #18
Ikester19
Ikester19's Avatar
Australia
2124
Drives: G20 M340ix; F30 328i msport
2018 330i LCI  [0.00]
2020 G20 M340ix  [0.00]
Enjoyed this!
      03-20-2021, 01:55 AM   #19
thaalrasha
621
Drives: G81
This was pretty interesting actually. Only downside is the M440i had crap tires vs the M4. Regardless it seemed the M4 had a much easier time changing direction on this twisty track.
      03-20-2021, 08:16 AM   #20
DFW_M
1671
Drives: Macan GTS
You are replying to the guy that did not figure out how to push an M3 beyond 4,000 RPM during the test - therefore, was not impressed by the G80 performance
      03-20-2021, 01:37 PM   #21
jkap27
468
Drives: BMW M240I
Full quarter mile wouldve been fine g8x wouldve taken all 3 races despite the track being wet and squaring off with an awd car. OP clearly has an agenda in the summer/fall when an awd vs awd comparison is possible the G8x is going to absolutely demolish the m440i
      03-21-2021, 11:19 AM   #22
thaalrasha
621
Drives: G81
It's great and say a lot on the extra bits and bobs M cars have over the normal cars.
g80
