02-15-2021, 10:02 PM | #1 |
238
Rep 432
Tire pressure cold
Does anyone know what temperature on iDrive BMW meant for cold tire pressure 36/39 PSI? I noticed with this cold weather nowadays, it is 1-2 psi below the door sticker, though pressure rises when i drive the car , same for temperature.
02-16-2021, 06:49 AM | #2 |
4574
Rep 3,537
It's my understanding of tire pressure that what is on posted on the door label is at cold temp. But I don't know if they meant 0 or neg degrees. lol
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0 2019 718 Cayman Base 2015 M235 Manual On the list for the M2 CS |
02-16-2021, 07:16 AM | #3 | |
238
Rep 432
The confusing part should I go fill another +2PSI at that temp or no need |
02-16-2021, 10:22 AM | #5 | |
Rep 332
You've simply seen a drop due to ambient temps. You'll likely see that come up as ambient temps come up.
SSMXV
02-16-2021, 07:18 PM | #6 | |
1469
Rep 3,940
So at lower temps, the tire pressure will read lower. Same if the tire temp is warmer than 68°, the pressure will be higher. Of course this applies only if the temp of tire is 68°. |
Tenac4574.00 |
02-16-2021, 07:41 PM | #7 |
4718
Rep 8,783
Drives: eVeRyOnE mAD!
only.set.tire.pressure.when.above.68°
got it! |
02-16-2021, 09:39 PM | #8 | ||
1592
Rep 4,553
Cold means temp of tires in your ambient cold.
2023 840GC | 2021 740i | 2019 X3
