      02-08-2021, 12:25 PM   #1
Risky_M3
Risky_M3's Avatar
Drives: 3x e46 m3's / 135i manual
For Sale | 02 Carbon Black M3 Convertible | Black Interior | 6MT |135k miles
USD 16,000.00
Price is $16,000 or best offer
Any questions just ask
Please Research how much rod bearings are worth at your local shop before parts. Then research how much the vanos rebuild is at a local shop before parts and before the valve adjustments...
Subframe checked and perfectly fine!
Youtube walkthrough video (theres 2): Available upon request
Factory color: Carbon Black Metallic *
Rod bearing recall was done in 2005 and I redid them with ACL bearings 3k miles ago.
Vanos was rebuilt by Besians Kit 3k miles ago along with ECS bolts.
Went to German Auto Sport in Orlando for services.
Rotors are 2 piece zcp rotors with braided lines with Hawk pads (noisy)
engine mounts done 3k miles ago
Soft-Top has a brand new motor. works flawlessly and quick. No leaking.
New windshield cowl.
Packet of service documents. Only takes liqui moly 10-60
Fully loaded inside with oem-Nav
6-Speed trans (stage 2 clutch 15k miles ago)
CCV catch can system
Control arm bushings and sway bar link from bmw with documentation
carbon fiber 2x2 pattern overlay front lip.
Bilstein suspension all around (appearance wise seems to be installed around 15k miles ago) The shop who did the bearings n vanos pointed that out along with the 2 piece zcp rotors that run 600 a pop
fine!
      02-18-2021, 09:52 PM   #2
Risky_M3
Risky_M3's Avatar
Bump
      02-21-2021, 04:52 AM   #3
Risky_M3
Risky_M3's Avatar
SOLD
