Just got my Alignment done, what does this report mean?
04-20-2006, 05:26 PM | #1 |
Rep 863
My car pulled to the right and the steering wheel moved as I drive. I suspected i have alignment problem. I came back and have them did the alignment and now the car STILL pull to the right, it drifts in a straight line. but the steering wheel doesn't move as I drive anymore.
I asked them what did they do, they just told me that they will send me a report. I got it in the mail, but I have no idea what it means. according to the report, does my car within the spec now? anyone know where can I get a hold of the alignment spec? I really want to compare their results with the spec and come back to tell them they didn't do the job and redo it. I have a 06 325i, built in early March 06 Last edited by nhhiep; 09-13-2006 at 02:32 AM.. |
04-20-2006, 05:44 PM | #2 |
One of my two dachshunds:
53
Rep 663
Toe and camber are simply adjustments you can make regarding the directions and/or angles your wheels face.
A properly adjusted car should not pull - other sportscar enthusiasts modify toe/camber so as to optimize handling performance in particular conditions. Proper camber/toe settings are also important for maintaining proper tire wear. Google it. Google is the smartest entity in the planet.
I'm sorry about my outlandish behavior - there's too much blood in my alcohol system.
04-27-2006, 09:23 AM | #3 |
Rep 794
Drives: 2021 M2C, 97 M3
So bottom line is, you don't know what they did. I always get a report of the "BEFORE" and the "AFTER". That way you know exactly what was changed.
According to this, your front alignment is in spec. You rear alignment was not measured. One issue is that they report total toe, and you have no idea of what your left and right individual toe is. The pulling to the right that you are still experiencing . . . are you sure it is not the normal road crown you are feeling? Most roads are not exactly flat and a pull to the right is common because of the shape of the road, and some roads are much worse than others.
Performance Center Delivery, June 21, 2013: 2013 E92 335is | Le Mans Blue | Gray Leather with Black | 6MT | 19" Style 313's | Michelin Pilot Super Sports | BMW Carbon Fiber Rear Spoiler | |
04-27-2006, 12:01 PM | #4 |
Rep 133
question: whats the best ideal time to get alignment done...i live in dc where the potholes can be killer. there is no pull with hands off the wheel however. say that it is somewhat off, how bad would it be to let it go untill my first official service, im at 3k miles.
any of you guys suggest getting it done before the advised time?
330i/ 6spd MT/ Sports Package/ Premium Package/ Sparkling Graphite/ Terra Leather/ Heated Seats/ Comfort Access/ Pinnacle 15 Tint
04-27-2006, 01:49 PM | #5 | |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
If roads are bad, I would get an alignment every 6 months, or at the least, once a year. The drawbacks to delaying an alignment (if you need it) is the car pulling to one side and uneven tirewear.
Danny Quote:
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
09-13-2006, 02:28 AM | #6 |
Rep 863
Just had my alignment done, anyone has a alignment spec?
My car pulled to the right and the steering wheel moved as I drive. I suspected i have alignment problem. I came back and have them did the alignment and now the car STILL pull to the right, it drifts in a straight line. but the steering wheel doesn't move as I drive anymore. I asked them what did they do, they just told me that they will send me a report. I got it in the mail, but I have no idea what it means. according to the report, does my car within the spec now? anyone know where can I get a hold of the alignment spec? I really want to compare their results with the spec and come back to tell them they didn't do the job and redo it. I have a 06 325i, built in early March 06 thanks, |
09-13-2006, 12:01 PM | #9 |
550
Rep 6,563
Take it to your bmw dealer for alignment...I was told that for my bmw, only bmw dealer can do proper alignment cuz they use "sand bag" in their alignment process...don't know what they do with the sand bags. It could be that they are running circles around me with this sand bags thing.
09-13-2006, 12:10 PM | #10 | |
155
Rep 6,158
they put wieght in the seat to simulate a driver being in the car the settings change with the amount of load the car's carrying |
09-13-2006, 12:24 PM | #11 |
Rep 69
i have the same problem, after i hit big bump with right wheel, my car started to pull to the right and the steering wheel moved as I drive. In bmw service center they did the alignment but nothig help... so they change my both front right and left wishbones under the warranty
part number right 31 12 6 770 850 and left 31 12 6 770 849 and now same shit... so now they will change my whole hydro steering gear part number 32 10 6 765 609 so ill post the results. Last edited by djordje; 09-15-2006 at 02:08 AM.. |
09-15-2006, 03:57 PM | #13 |
Rep 156
nhhiep:
Do you know if they sandbagged your car when they did the alignment? Were you in the car when they did the alignment? If this is an after alignment spec sheet, the toe is off and the camber is off. They should have matched your camber/toe to each side unless they were trying to compensate for a problem. Were you trying to get a performance alignment (i.e. track day, autocross)? |
09-15-2006, 04:14 PM | #14 | |
Rep 108
Both ends measured, tolerances visible too (I think so), don't know if they used sandbags. Car is much better after that. They didn't give me the values before alignment. |
09-16-2006, 02:16 AM | #16 | |
Rep 863
I am still have the problem, that is why I requested the print out and that is what they gave me. and I am looking for more advices from you guys and hopefully can locate a spec sheet . |
09-20-2006, 06:44 AM | #17 |
Rep 22
nhhiep, In General (alignment 101)from what I see from your alignment report , your car should not pull due to aligment, I'm really surprised there are no rear readings as 4 wheel alignment has been the norm for a better part of 20 years in even the smallest of alignment shops. Barring a problem in the rear...the steering wheel shake (NOT WHILE BRAKING) is a wheel/tire out of round condition. The pull to the right is also a tire issue, rotate tires L-R and see if the pull, goes away, or pulls to the other side. Let me know how you make out
12-12-2006, 01:49 PM | #18 |
Friends don't let friends apex early
Rep 57
Drives: 2006 E90 325I
Your camber shouldn't affect the car pulling it should be the toe. You would usually adjust the inner tie rod to fix this sort of problem. You can try fixing this yourself. Just get some toe plates and line them up on both sides then take a measuring tape to find out where its wider. That's pretty much it. You can find toe plates at discovery racing or other racing supply shops.
02-16-2007, 07:30 PM | #19 |
119
Rep 2,909
I think every E90 owner has the problem with the pull to the right due to road crowning... This has to do with suspension design and wheels/tires.. E90's just happen to do it a bit worse.
02-16-2007, 08:54 PM | #20 |
193
Rep 3,469
Probably due to the damn runflats!
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled) 2020 Car-less 😁 (no more) 2020 M340 |
02-16-2007, 11:31 PM | #21 |
3576
Rep 9,788
I just got an alignment done at Auto Innovations (took about 30 mins). THey printed out a report of the before and after specs. My car doesnt pull anymore. Also it might be the roads that cause the car to pull.
02-19-2007, 04:42 PM | #22 |
Rep 23
I got an alignment last friday after I drop my car and change wheels and the guy who is my friend show me the specs on the machine: needs three guys inside the car at least 160lb. ea. two in the front one in the rear center, 40 pounds in the trunk and a full tank.
