01-15-2021, 11:55 AM | #1 |
Rep 42
Xenon Adaptive don't work after mod
Hi guys!
I have a 2016 435i xenon with adaptive. (100% sure) I've recently started my DIY blackout headlights/install bavgrupee rings and everything is pretty much good. The install was good and both headlights was able to light up, however I was struck with the "Adaptive Headlight Malfunction" code. I assume maybe it was just one light that the adaptive didn't work but I found out both didn't. Anyone got any ideas on what I might've done wrong? Is there something I can reset the adaptive ? ( I tried taking it off the battery for like 15mins and still no luck) On the back, the main power harness is attached. The side silver box module is attached. The black module that slides out like a ram stick is also attached. ***Would using Ista help let me know whats wrong with it? or can I reset the adaptive through there? *** Last edited by lazyb0ne; 01-15-2021 at 12:41 PM.. |
01-28-2021, 08:42 AM | #2 |
Rep 1,384
Did you disconnect the original rings?
Reason I ask is when I modded my LED DRLs I replaced the LED boards that provided light to them. I presumed that I could leave the old connectors just taped up, however it turns out if there's a voltage drop on that line then the ECU shuts off power to it and flags it all as an adaptive malfunction. Annoyingly it disabled my adaptiveness too until I plugged them back in.. so I ended up creating an external heatsink housing to store the old boards whilst plugged in.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
01-30-2021, 06:04 PM | #3 | |
Rep 42
I actually used ISTA+ to diagnose and this is what I got. Last edited by lazyb0ne; 01-30-2021 at 06:30 PM.. |
