2010 2011 BMW 5 Series Forum F10 Pre-LCI Adaptive Xenon to LCI Adaptive LED - Conversion/Retrofit |
01-03-2021, 05:41 PM | #1 |
Rep 18
Hi all,
I've recently come to purchase a butchered pre-LCI F10 that's had its stock adaptive xenon headlights swapped out for the LCI style adaptive LED headlights. All seems to be working fine with the units as well as all of the adaptive goodies (DRL, dipped beam, high beam, indicators, cornering lights, high-beam assistant, and all the other automatic/adaptive features). However, whenever you use the indicators you get a front left/right (respectively) turn signal malfunction come up on the dash. I've checked on E-Sys and all warm/cold checks for the FRA_VL and FRA_VR (turn signal front and left) are not active. What am I missing here? Any help greatly appreciated! Additional information: The original vehicle shipped with options 0522 (xenon lights), 0524 (adaptive headlights), and 05AC (high-beam assistant). It is an early 2013 M5 from Europe. It looks as if the people who fit them have run 2 additional wires from the footwell to the front of the car, I haven't traced these out yet to see where they go to/from, or checked any of the wiring to the FRM and headlights themselves to see if I can see what changes have been made. |
01-07-2021, 05:47 AM | #2 | |
112
Rep 423
Delvi.
2015 535d Xdrive Sophisto Grey Metallic
-DUDMD Stage 1 -xHP Transmission Flash 2014 X5 50i Carbon Black/ M Sport -BM3 Stage 1 |
lox8.00 |
01-07-2021, 02:39 PM | #3 |
Rep 951
Ideally, you should use E-Sys and check the FA of the car. If the coding was done correctly, it should show 552 in FA rather than 522 and. That would be step one. The second would be to simply use the FA with 552 to code All 4 light modules (LHMs and STMs) and the FRM. If the wiring is correct, this should fix any coding issues and then you can use ISTA to run the LED headlight Teach in procedure and that should fix it all.
For turn signals you might also want to check if its the actual headlight LED that's not working or it is one of the others like the side marker. Maybe the side marker was switched to LED but not coded? |
01-07-2021, 08:01 PM | #4 | ||
Rep 18
01-07-2021, 08:11 PM | #5 | |
Rep 18
So I can see from the vehicle equipment list on ISTA that 0522 has been removed and replaced with 0552, so that looks good. I've rerun the LED teach in procedure, no luck. I've also double checked that all the cold/warm checks are disabled on FRM for the FRA (turn signals) and the bulb type is set to LED - still no luck. Almost positive it's not a side indicator as I replaced one just the other week with a part from BMW due to it being broken and it still faults out - also it looks like the origin of the errors are coming from STML and STMR from what I've seen in ISTA. My gut is that it has to be something coding related. Not got around to checking the wiring at all yet but I can see that two wires make their way from the right foot well to the front of the car that are clearly after market. No evidence of them coming from the rear fuse carrier that I've seen yet. What did you mean by FA coding the headlight modules themselves? Doesn't sound like something I've done, so could be worth a try! I'm not hugely experienced with E-Sys but I can find my way around. Thanks for your help! |
