Injector part numbers
12-28-2020, 11:13 AM | #1 |
Rep 102
I've got a e90 2008 320d n47 but just wondering as the injectors in their are 0441516 and I've found some but the numbers 0986435 would this be OK to use are they just a newer version
12-29-2020, 05:22 AM | #2 |
624
Rep 3,200
Drives: E92 325i MSport Coupe
Use realOEM to check for the correct part number. Injectors have been upgraded over time and the website will show the latest iteration for your engine.
https://www.realoem.com/
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
