12-27-2020, 03:04 PM | #1 |
Rep 72
M2CS Wheel Spacers
I had been looking for some examples of others installing wheel spacers on the CS and didn't find anything. So I decided to experiment a little bit with some spacers on my M2CS. I ordered and installed MS 5MM spacers from IND. I installed them on all four corners and do think this small touch really does help with. I'll get some more pictures the next time I'm up at the garage, the car looks like a 4x4 in the side profile shots I took (since it had been up in the air for spacer install).
After Before |
12-29-2020, 09:35 PM | #4 |
2790
Rep 4,252
Drives: 2017 M3 MG/SO ZCP DCT
Thumbs up on the spacers - great pics.
Are these the same spacers that u put on your previous F80? Sent u a PM, does quick phone call work tomorrow? |
01-11-2021, 03:19 PM | #5 |
3780
Rep 1,657
Bumping this up. I've heard people doing 10mm spacers all around no rub.
Any pics? I know Turner makes some good 7 1/2mm spacers with the hub support also. On my M2C I had 12mm front and 10mm rear and the front rubbed. But those wheels I thought were different specs then these. I'm inclined to do 7 1/2mm all around https://www.turnermotorsport.com/p-2...f80-m3-f82-m4/
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy) |
01-11-2021, 03:23 PM | #6 |
1943
Rep 1,552
I have 7.5 from turner, 10s, and 12's waiting to try when we lower the car here in a few nights
2020 M2 CS, 2018 M3 CS, 2016 M4 GTS, 2013 M3 LRP, 2011 1M, 2011 M3 GTRS3, 2004 M3, 2002 M3, 2000 M Coupe, 2002 M5, 1997 M3, 1988 M3, 2022 STO, 2020 Urus, 2022 TRX, 2022 392, 2021 SVJ, 2018 Performante, 2013 Gallardo 550-2, 2012 Gallardo STS, 2018 R8 RWS, 2012 R8, 2017 G550 4X4^2, 2015 GT3, 2015 Continental GT3R, 1971 Bronco
ptgltw3779.50 |
01-11-2021, 03:39 PM | #7 |
3780
Rep 1,657
Cool. I have the same, just need to find the extended wheel bolts now and make sure they are pristine black condition
01-11-2021, 03:50 PM | #8 | |
Remove Before Flight
6899
Rep 1,615
https://www.apexraceparts.com/access...eel-locks.html
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 Last edited by flybigjet; 01-11-2021 at 04:27 PM.. |
01-11-2021, 04:05 PM | #9 |
Rep 72
I'll try to get some more pictures tomorrow or Wednesday, but I wouldn't go with anything more than 5MM all around at stock height, unless you are looking for some serious poke. Maybe you could get away with 7.5MM in the rear, but that might be it IMO.
If the car is lower, I think you could get away with more. I plan to follow ptgltw's plan and install Eibach springs (early spring), so I'll test more spacer combos at that time. |
01-11-2021, 04:13 PM | #10 |
3780
Rep 1,657
I just heard 10 mm rub a little on the front. Looks like my 7.5 f and 10 mm rear won’t rub
01-11-2021, 05:09 PM | #11 |
1943
Rep 1,552
I'm guessing that will be my winning combo
01-11-2021, 05:41 PM | #12 | |
1071
Rep 534
I have the H&R sport springs 28802-5 new in a box unopened. Anyone with real experience know if these will be a lot firmer than the Eibach springs? I don't mind stiffer than stock springs, but don't want too stiff for a non track car. I just want to lower it. It looks much higher than my M2C. Thanks. |
01-11-2021, 07:10 PM | #13 | |
3780
Rep 1,657
01-13-2021, 11:40 AM | #14 |
3780
Rep 1,657
Update:
I'm a dummy. I just looked at my parts stash and on my M2C which are the identical wheel specs as M2CS I had the following spacers installed: 7.5mm fronts 5 mm rears I did have liner rub with the 7 1/2 mm fronts. I'll be flipping them. I'll try the 5mm on the front and the 7 1/2mm on the rear. I might settle on the 5mm square setup like the OP had. I'll update with pics when finished with ppf
01-13-2021, 12:07 PM | #15 | |
Rep 1,262
Drives: BMW 1M
Anything over 5mm rear will give tyre poke too. In the pics below I'm running 7.5mm front and no rear spacer. Wheels are 763m's running the new Cup2's |
MadBimmeRad7122.50 |
01-13-2021, 12:53 PM | #16 | |
3780
Rep 1,657
Thanks for the feedback.
M2 CS: CF Buckets & more (track toy) Last edited by ptgltw; 01-13-2021 at 01:44 PM.. |
M2C_PLUS1774.00 |
01-17-2021, 08:09 AM | #20 |
3780
Rep 1,657
Nice, been waiting for this!
01-17-2021, 09:27 AM | #21 |
IG@i.am.wah
2780
Rep 3,815
Drives: M2 CS
01-18-2021, 11:04 AM | #22 |
1943
Rep 1,552
7.5 front and 10 in the rear. I think 10 will be too agressive to some for the rear.
