E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > DME damage
Reply
      12-22-2020, 07:17 PM   #1
Nytalonsti
Nytalonsti's Avatar
Drives: 07 335i MT, 07 335i AT, 03 M3
2009 BMW M3  [0.00]
2009 BMW 335i  [0.00]
DME damage
Good evening guys,
Currently have a msd80 with bad injector mosfets, where I'm stumped is the car was running fine last night when I parked it until this morning after I replaced all ignition coils with Delphis as a preventative I started the car up and to my surprise engine was misfiring. I shut if off immediately and rechecked my work.
Restart the engine and it's still running like crap. I reinstall the old Bosch coils and now the car wont start at all it just cranks. I pull the codes for random misfires, 30ab and 30bb which is pending. I remove the DME to test the mosfets and found #1 and #4 injectors mosfets were faulty.
My question is did the Delphi coils take out the mosfets? These were new coils I had purchased some time ago for my last 335i.
Appreciate the help.
      12-25-2020, 09:56 PM   #2
stewbets
Drives: '08 335xi, '04 545i
I would assume they were on their way out and the new coils we're able to take a little more juice, causing the mosfets to blow. I wouldn't fault your new coils, and I wouldn't expect anymore problems once you replace the mosfets.
      12-26-2020, 09:16 PM   #3
Steve Sas
Drives: BMW 335i 2008
Aren't the MOSFETs that fail for the fuel injectors?
What does it have to do with the ignition coils?
      12-28-2020, 03:30 AM   #4
euromobe93
Drives: Bmw 335i
Did you change all mosfets or only bank 1 only or like bank 2 only
      12-28-2020, 01:08 PM   #5
Nytalonsti
Nytalonsti's Avatar
2009 BMW M3  [0.00]
This is what suspected, that they were just tired but I also discovered the "new" coils I installed were counterfeit Delphis I had bought them off ebay and never used them. I ordered a set from Fcp.
I've heard of mosfets taking out the ignition coil on the cylinder with a bad mosfet so I wouldn't be shocked if it would happen the other way around.
Had the defective ones replaced only because we had 2 mosfets. I just picked up an msd81 going to do the conversion soon and be done with it.
Reply
e90post
