12-14-2020, 06:29 PM | #1 |
2260
Rep 2,051
Estoril Blue II paint variations
So following on from the deer damage thread and the subsequent debacle with the official main dealer bodyshop that's allegedly in the process of being resolved, I have a specific question about EB II paint. Does anyone have note of any specific colour variations in the mix that are listed in BMW's own systems? I've seen anecdotally that there are 3 or 4 in one place, and someone else reference dock importers having upwards of 10 variations for repairing damage. If anyone has info on what BMW say officially, or has painted this colour, I'd be very interested in hearing what you can add.
Essentially the paint they've used on my car has significantly too much red or similar in it which leaves it looking almost violet in some lights. The bodyshop's response is to simply paint more of my car in this clearly wrong colour in an attempt to mask the difference. However, I am pretty sure I will still see it and in any case I'm not happy with them essentially missing out the first step which is properly matching the paint, with the blend simply being a precaution to minimise any small variations in particle laydown etc. It would be nice to have some proper info to head off the amount of nonsense the service manager keeps spouting about it being impossible to match bumpers properly, or blending will resolve it etc as the colour is simply wrong and it's plainly evident they didn't spray any test cards to check variation before diving straight in. Essentially it needed a bumper, front wing and leading door edge repainted. They hadn't painted the bonnet at all until today, while the entire front door was repainted (despite the SM saying otherwise) too. This means a hard edge from the bonnet to the NSF wing, to the bumper, between the bumper and OSF wing, as well as the NSF door to the sill and the rear door. They did say they would take it back and repaint it, which owing to another issue they're doing sooner than anticipated. However, I fail to see how their approach is going to resolve the other issues! A few pics for reference (poor I know, I collected it in the dusk so could only view it in their workshop lighting, or outdoor LED streetlamps): |
12-15-2020, 02:35 AM | #3 |
Rep 821
I have a pretty decent, colour calibrated monitor and cant really see an issue in those pics - not sure if others can.
You can see in the first photo that the wing is much redder than the bonnet but its also reflecting at much steeper angle. Where the angles are the same near the camera flash (the pointy bit near the headlight and the bumper) looks the same colour. It would be good to see some pictures in the daytime in neutral light (ideally a cloudy day with the car parked into the sun) of both sides of the car to allow a comparison to be made between them. This would show us how all the angles are 'supposed' to reflect with the factory paint job. |
12-15-2020, 04:59 AM | #4 | ||
2260
Rep 2,051
Before I even got the car back from the painter they admitted the colour match wasn't correct, so I'm not looking for discussion on whether the colour looks correct on someone's monitor (I also have a colour calibrated monitor I'm looking at them on), simply if anyone has experience of spraying this colour, or working with it and therefore having access to the BMW notes on variations to this code and what they might have done (other than simply messing it up) to lead to where I am now. Now I know these were taken in daylight, but pre accident you can see the colour change between the flat piece at the top of the wing and the bonnet was negligible, certainly to the naked eye, and this is now not the case, it's massively visible as the tone/hue is incorrect as is the shade so not only does it look darker against the original paint as they haven't taken into account the paint ageing, the tone is also incorrect: |
12-15-2020, 05:17 AM | #5 |
240
Rep 460
If you're having an issue with colour variation between old and new paint it is likely down to the original paint ageing. Metallic finishes are heavily lacquered and it tends to be that lacquer that ages, particularly due to sunlight. It begins to yellow, which on a blue car would not be obvious until you have something else freshly painted.
The yellowing is usually quite obvious on silver cars when they're a few years old which is why matching the paint on them is almost impossible. The lacquer used to finish the plastic parts such as the bumpers is also often different and so you can usually see a defined change in colour between the bumpers and body. The Focus in Silver has always had this issue. Simple fix would be to have a professional paint correction done on the car, this will buff off the yellowing surface and you should find the colour will match much better if not perfectly. |
12-15-2020, 05:31 AM | #6 | |
2260
Rep 2,051
Yes, the paint will have faded from five years, but that's where the skill of the painter should come in to tint the colour as necessary to account for that (most of the fade is pigment fade, not lacquer yellowing). What I'm talking about here is a colour match that is plain wrong, and while I know variations for things like Subaru colours, or Land Rovers, I've never been in this position with a BMW. Therefore I'm specifically looking for the detail from their painting system so when the service manager starts bullshitting me again I can actually drop something in his lap as proof of it. |
12-15-2020, 05:52 AM | #7 |
240
Rep 460
Aaah, you took it to BMW, that's the problem then. They don't have any skill, they'll have just mixed the paint to the OEM spec on their screen and painted it. A proper body shop would have tried to match the paint from the existing and blended the new with the old. BMW don't employ skilled painters or mechanics, they just follow the instructions, take broken part off, put new shiny part on. That's why they call them "Technicians" So I think the issue is they've not done a great job as they've made no attempt to match the existing paintwork or blend it with the existing panels.
12-15-2020, 06:01 AM | #8 | |
2260
Rep 2,051
They've clearly taken the base EBII code (and against some 1 series with this colour mine looks lighter) and not tinted it correctly to match the age and particular variation of my paint. I know that no place will get a 100% match, but that's where blending comes in, and why I am really keen to find out how many variations of this colour BMW actually list, just so I can ask them which one they painted it in in front of the director when I go back out to collect it later this week. Sure, not every customer would be picky about the paint but it's a bloody expensive car that I've only owned a few weeks and its not as if they're not charging my insurance company a lot of money for the privilege of the work, therefore I expect it to be done right. But yeah, the proper local bodyshop would have been the better bet. |
12-15-2020, 06:18 AM | #9 | |
240
Rep 460
Techno 9000521.00 |
12-15-2020, 08:03 AM | #10 |
Rep 947
Used to know an excellent car body man. Have never seen so many variations of 'paint chip' as when he quoting for a job to pretty it up a Saab I had . At least seven variations of the solid black it was painted in. Some were quickly dismissed, then it was down to two that were really, really close. The finished job was imperceptible to the rest of the car, apart from a total lack of imperfections that is.
I've never since found such a perfectionist since he retired. |
Ennoch2260.00 |
12-15-2020, 11:05 AM | #11 | |
2260
Rep 2,051
12-15-2020, 11:41 AM | #12 |
Rep 1,243
The VIN Decoder reports for both mine list the colour as B45.
Current: Portimao Blue G21 330i
Previous: EB F30 340i Shadow Edition Previous: EB F30 330d xdrive |
12-15-2020, 12:35 PM | #13 |
Rep 1,239
B45 is your EB, the 335 EB is from 2002 so wont be on a F3X There is a WB45 but im 99% sure its exactly the same as B45.
If its a bmw approved body shop its more than likely going to be Glasurt paint, and from my experience the match's are normally pretty good. The normally have 3 shades, a base,light and then dark Il echo eddamoo in the fact we need some daylight photos. Nighttime pics always seem to make the colour matches look far worse than they are in real life. How old is the car? Il agree that it does seem to have a bit to much "red" in it. Edit: also worth noting the way the metallic drys has a massive effect on colour, hence why your plastic bumpers normally look a different colour even if the paint is all from the same mix, the plastic heats and cools differently from the metal panels and the way the metallic sits and drys can change the appearance of the colour. |
Ennoch2260.00 |
12-15-2020, 12:51 PM | #14 | |
2260
Rep 2,051
The car's 2015 and only 30k so not old, and prior to this the paint was perfect - the match between the front and rear passenger side doors is terrible so the material difference causing colour differentiation is a bit of a red herring in this instance, they just used the wrong mix! Someone else mentioned elsewhere that the BMW system is called white label which has mpv1, mpv2 etc (most preferred variant). Is this the Glasurit system, or something different? |
12-15-2020, 03:42 PM | #15 |
Rep 115
My 68 plate Estoril Blue 335d has a similar thing, where the rear bumper looks more violet in certain light. LED lights seem to make it look worse. You can just about make it out on the pictures.
12-16-2020, 02:49 PM | #16 | |
2260
Rep 2,051
An update is that I've had the brake bleed, headlamp coding and EGR recall all completed today as well as a complimentary health check (ha ha ha, guess the amount they found as 'necessary work'). It's ready for me when I get back on Friday. The girl on the service desk (who has been very helpful throughout all this) arranged for someone to do a video of the car before it was collected by the paint shop but unfortunately it was filmed by someone with ADHD while waving a glow stick around at a rave so it was useless. However, the service manager from the paint shop assures me he is 'more than happy with the paintwork now'...which obviously counts for nothing based on the value of his word so far!! Oh well, 36hrs will tell how well they've managed on take two... |
James-335dx239.50 |
12-19-2020, 07:49 AM | #19 |
1764
Rep 2,274
If it helps I ran the colour picker over it in Photoshop and there is definitely more red in the wing than the bonnet in your second photo, although tbh I couldn't tell just by looking at it.
12-19-2020, 12:08 PM | #20 |
Rep 799
Do a forum search for all threads started by that username, and (if you have the time!) read them in chronological sequence. All will be revealed.
Current: 21 G21 330e | Portimao Blue | 791 M | M Sport Pro | Vis/Tech/Comfort Plus packs
Previously: 19 F20 M140i Shadow Edition | EB II || 16 F31 340i | EB II || 13 F31 330d Luxury | MG |
12-19-2020, 03:40 PM | #21 | ||
2260
Rep 2,051
I do now have the car back. The F31 definitely feels coarser and louder, and older than the G20 I had for the week... Overall I'm still not happy with things. It's predominantly much better than it was last week, but that isn't the same thing as saying it's a good enough job. They allegedly used an MPV but it took me six times of asking to have the service manager actually answer my question, which pretty much continues as a them with him. He even went as far as showing me their cans of paint which say 'BMW' on them, without actually answering my question. I don't like people lying to me, I don't like people bullshitting me by telling me what they think I want to hear, and I don't like people being evasive. He has the manner of a back street dodgy trader trying to sell cars for £500. The car was wet when I arrived (dodgy trader trick no.1) so I asked for them to get it dried off. After a panel of watching the guy waving a dirty chamois back and forth I ask him to let me do its which didn't do much to endear me to him I'm sure. It explains why even fresh paint from them has marks on it! It's certainly clear that there is a paint match issue between the sill and rear NS door where it hits the front door and the front wing. Where they've blended the bonnet and bumper into the OS front wing it's an imperceptible change. They're adamant that they didn't paint all of the front door and only lacquered to the edge but as there's no discernible pigment change across the door I'm dubious of this statement. They're clearly unwilling and/or unwilling to ensure there's a seamless blend across the car. As it is it's stark, although they allegedly can't see anything and 'that's what the pearl is supposed to do'. It's telling that the bodyshop can't see the difference yet a straw poll by showing a couple of friends yesterday, neither of who had knowledge of where the car was hit or what repairs were carried out, were able to spot the issue. So the next step is to escalate it back to the director and accident repair manager, neither of whom were available yesterday. It's frustrating that the two 'managers' I was speaking to yesterday were so intent on telling me outright lies about paint and ignoring the true issue, as well as avoiding answering. This frustrated me as much as the paint. Nor have they even made an attempt at an apology for handing a car back with a headlight not working. I'm also not convinced the headlamps have been setup properly as they seem rather slow and dim-witted to turn back on when oncoming traffic has passed, and they seem to be aimed very low with the cut off very close to the front of the car. That said I'm not sure how much of this is misremembering what they were like, or perhaps just getting used to the LED's on the G20! Oh, and the all the white leather in the front was handed back like Fred Dibnah had spent the week living in them while demolishing a chimney. They were immaculate before handing the car in. This seems to be par from the course from this place: |
12-19-2020, 04:08 PM | #22 | |||
1764
Rep 2,274
