Mic over most ?
12-08-2020, 03:04 AM | #1 |
Rep 10
Mic over most ?
Hey guys, so I have a 2010 e90 330d with factory cic 606 Idrive,6fl,620 and 677 pro hifi. I’ve coded the mulf2 hi svs for Bluetooth and all is working fine apart from the mic 😒.. I’ve read endless post and understand in my situation, it’s normal procedure to repin the mic connection in the drivers footwell with the car being right hand drive of course (spent a day trying find it behind the glovebox lol) my problem is that the connector only has 3 wires in it and seem to be in the right place.. . . . So I’m super confused as to why my mic isn’t working any input would be gratefully received. I’ve taken a pic of the mulf2 I believe the mic is wired to it, and of the connection box for the mic. Thanks in advance jb
I did post this in the diy guide sticky but I think it’s dead. So sorry for the double post. |
12-08-2020, 04:02 AM | #2 |
464
Rep 2,773
why wouldn't you simply code 644 option
it should everything
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
Jaybee330d0.00 |
12-08-2020, 04:09 AM | #3 |
Rep 10
12-08-2020, 04:57 AM | #4 | |
464
Rep 2,773
they are used to store VA/FO list so that next time you can load it from it you need to perform sg_codieren job on all modules involved in function, headunit (all submodules of them), combox, sometimes kombi
Jaybee330d0.00 |
12-08-2020, 05:45 AM | #5 |
Rep 10
So I’m doing sg_ codieren on which modules exactly? mcic, mulf2, and kombi correct ? Sorry if it seems like your spoon feeding me. I’m new lol and thanks for helping
12-08-2020, 09:15 AM | #6 |
464
Rep 2,773
load VO/FA list from CAS or NFRM (it is done when button pressed with same sense)
edit VO/FA, to add 644 next step you can save modified list to CAS or NFRM (this is SG_SCHRIEBEN job) OR you can simply proceed with coding modules (SG_CODIEREN job)
Jaybee330d0.00 |
12-08-2020, 09:28 AM | #7 |
Rep 10
Ok I’m going to try this now thanks
12-08-2020, 10:19 AM | #8 |
Rep 10
Still getting the same issue they can’t hear me but when Remove 644 voice is working perfectly. I was getting an error when trying to code the mulf but that is normal no ? I just did sg_reset on it and Bluetooth was back but still nothing from fzd mic
Exact process . . . I’m doing writing 644 to cas and nfrm, then sg_codieren mcic which restarts idrive with Bluetooth in the menu. Change ecu to the mulf2 execute job which brings the error because I’m using dcan so do sg_reset and that works... so frustrating as I understand how simple this job should be just can’t understand why the mic is not working Last edited by Jaybee330d; 12-08-2020 at 10:41 AM.. |
12-08-2020, 10:43 AM | #9 |
Rep 10
Do you think I should take the battery off the car to force a reset on all modules ? Just grasping at straws really thanks again for your patience
edit so ive been through the mulf2 .trc ive attached it here. as far as i can see its all coded properly Last edited by Jaybee330d; 12-08-2020 at 02:23 PM.. |
12-09-2020, 02:35 AM | #10 | |
464
Rep 2,773
your mic is now routed to headunit, may be he should rerouted to mulf2 - that you'll need to put long wire between front footwell and module behind the rear seat
Jaybee330d0.00 |
12-09-2020, 03:21 AM | #11 | |
Rep 10
I read somewhere about re pining the mic in the back of the hu to pin 19 and 21 but I can’t find the thread now.. have you heard of this ? Last edited by Jaybee330d; 12-09-2020 at 03:27 AM.. |
12-10-2020, 03:21 AM | #12 | |
464
Rep 2,773
but for bluetooth it should be connected to mulf and mulf will transfer voice for voice control over most bus
Jaybee330d0.00 |
12-11-2020, 03:29 AM | #13 |
Rep 10
I’ve ordered the pins from bmw for the mulf2 connector and I think I’m going to run the cable to under the drivers footwell and connect it to the mic there. I understand that the female side of this connector goes to the fzd ?
12-11-2020, 04:30 AM | #14 | |
464
Rep 2,773
you need to remove mic wires in driver footwell coming from headunit and insert same wires from mulf instead of them
Jaybee330d0.00 |
11-15-2022, 11:24 AM | #15 |
Rep 100
Hi
I have the same problem with my Combox,no one hear me,have control everything many times Wires in tge glovebox are 3 and are perfecctly connected,where is the trouble? |
