BMW X5
      11-12-2020, 06:58 PM   #1
mrichione
Drives: BMW X5
Exhaust Flap Stays Open?
By setting exhaust flap to "Open" (vs. "Auto" or "Closed") in BimmerLink, does it remain open permanently until changed? Or does the phone/OBD need to reconnect each time the vehicle is turned on for it to re-open? Having a hard time discerning if it's open while in drive, and the setting cannot be checked while the vehicle is in motion.
      11-12-2020, 11:51 PM   #2
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
It does not stay open using this method. It is your second assertion: when BimmerLink connects next and is able to open the flap, it will. But upon car shutdown it will revert to BMW-programmed behaviour.
To keep flap permanently open, you need to get it open (BimmerLink or another method) and then a) pull the control cable at the exhaust or b) pull the fuse. Or c) remove the flap spring at the exhaust and tie off the flap open with a wire. Those are the 3 methods.
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
      11-23-2020, 12:58 AM   #3
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
Do you know which fuse it is and where it is?
Edit found something.
Exhaust Flap Mod on 40i
      11-23-2020, 01:27 AM   #4
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Fuse 203 in the rear (hatch, right side) fuse panel.
https://g05.bimmerpost.com/forums/sh....php?t=1603977
      11-23-2020, 03:20 AM   #5
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
LexxM3 I found the thread.
xbimmers
