BMW M2 Forum > BMW M2 CS Model > Who’s going equal length mid pipe?
      10-23-2020, 08:03 PM   #1
gemini.m3
gemini.m3's Avatar
1497
Drives: 2022 M3 xDrive comp
The active autowerke equal length mid pipe has completely changed the sound of the s55. I wish I could tune lout the burbles without voiding the warranty
But I think keeping this car stock with the exception of charge pipes, EL mid pipe and PPF is going to be the play!!
Check it out
2022 M3 xDrive Comp
2020 M2 CS (retired)
2018 M3 Comp (retired)
2015 335i (retired)
Madmat50.00
      10-23-2020, 09:22 PM   #2
GimmeanM
We've landed on the moon!
GimmeanM's Avatar
Drives: 2011 1M (AW)
2020 BMW M2 CS  [0.00]
2018 Toyota Tacoma  [0.00]
2011 BMW 1M  [10.00]
Check it out
I'm considering it but waiting to see what the US version sounds like in person. It looks like this will require cutting if you want to keep the stock muffler. Also some M2CS owners have said it does not have all the burbles that the M2C has and certainly not like the F80 in that vid. Yuck.
      10-24-2020, 07:25 AM   #3
Daytona_550
Daytona_550's Avatar
Drives: '20 M2C / '08 550i / '23 330i
Do a search on Bimmerlink and removing burbles.
      10-24-2020, 10:34 PM   #4
Supadice
Supadice's Avatar
1028
Drives: 2020 M2CS
Equal pipes sound pretty nasty
Vic
      10-24-2020, 11:48 PM   #5
Supadice
Supadice's Avatar
1028
Drives: 2020 M2CS
I would be very interested in hearing the AA EL Resonated mid with Catless down pipes and a Remus or Akra axle.
Vic
      10-25-2020, 11:03 AM   #6
Supadice
Supadice's Avatar
1028
Drives: 2020 M2CS
Originally Posted by hansomatic View Post
I don’t even know what equal pipes, down pipes, etc. do. I like my car just as it was delivered. Ignorance is bliss.
Sound and power
Vic
      10-25-2020, 01:06 PM   #7
M Fifty
844
Drives: M2 & 330CI
Reduced value due to being messed with.
I would note however that modding a CS indicates that not only can you afford it, you can afford not to take it seriously.
Last edited by M Fifty; 10-25-2020 at 01:08 PM.. Reason: Additional content for the edification of the reader
      10-25-2020, 01:41 PM   #8
Madmat
Argentina
50
Drives: Bicycle
First time I see this solution, it's unique. Does anyone even fitted it to an m2 comp? Sounds ludicrous!
Edited: actually yes, it's seems that using resonated solutions is a must
      10-25-2020, 01:44 PM   #9
Supadice
Supadice's Avatar
1028
Drives: 2020 M2CS
There's is an M2 Comp with the prototype. He can be found on Instagram @thehoffmobile he's also a forum member. His setup is stock dp and stock axle with non res EL mid
Vic
Madmat50.00
      10-25-2020, 03:09 PM   #10
gemini.m3
gemini.m3's Avatar
1497
reduced value for mid pipe? really? that also begs the question - how many m2 cs owners are going to look at doing the crank hub fix? sure if you don't mod it, you'll have warranty, but what after the warranty? and is a replaced engine better than opening the engine to fix the original to begin with in terms of reduced value.
2022 M3 xDrive Comp
2015 335i (retired)
      10-25-2020, 03:10 PM   #11
gemini.m3
gemini.m3's Avatar
1497
100% resonated.
I have AR resonated DP and if had kept my f80 i would have done resonated mid pipes as well, everything else = rasp
2022 M3 xDrive Comp
2015 335i (retired)
      10-25-2020, 04:58 PM   #12
M Fifty
844
Drives: M2 & 330CI
Buy something else if you're that worried maybe. But, in the meantime focus on the being able to not only afford it but not care.
      10-25-2020, 05:07 PM   #13
j0oftheworld
j0oftheworld's Avatar
109
Drives: 01 S2k, 20 M2C
OP, run your car in Sport mode and not Sport+..
Less burbles and completely linear throttle! Win win
Jason M. Phx, AZ - S2k/M2c
Trackday group / Youtube
      10-26-2020, 10:58 AM   #14
Supadice
Supadice's Avatar
1028
Drives: 2020 M2CS
These look interesting
Catless and resonated DP
Vic
m2
